Question about Splendide ARWXF129W - Washer 24" Whit ARWXF129W
I have a Splendide washer Mod.ARWXF129W.It quit suddenly before the spin cycle.When I attempt to restart it there is a quick loud buaa and in the display window H20 displays and it will not start and the machine is full of water.
    Top Expert:
  • Splendide Master
  • 8,163 Answers
Bad drain pump at bottom
Posted on Oct 29, 2017
5 Suggested Answers
SOURCE: 2100 Splendide
Thanks for the response, mine ended up being one of the connector wires connected to the wrong pin. Reviewed the correct plug connections and now it works properly. The two wires are easy to miswire according to the sales folks where I bought the board.
John
Posted on Jun 19, 2008
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
rogrrabbit
  • 986 Answers
SOURCE: I have a Splendide 2100 washer/dryer. Washer
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 16, 2009
  • 37 Answers
SOURCE: for wd802co the machine is
have you checked the water pump that draws the water out of the machine there maybe an obstruction like a sock or something. Make sure the pump is turning freely there maybe a blockage there. Also check the exit hose as well. Gain access from the rear.
Posted on Aug 23, 2010
How to put into test mode arwxf129w
if you put dial on start should fill then turn to spin then to rinse then to drain
Jun 10, 2014 | Splendide ARWXF129W - Washer 24" Whit...
H20 fault code splendide washer
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Nov 19, 2013 | Splendide ARWXF129W - Washer 24" Whit...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Splendide ARWXF129W - Washer 24" Whit ARWXF129W Logo
76 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
