Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
My 55313 power light dose not come on
I have a mitsubishi ws-55313 the tv will not turn on and the green power light will not come on either. I checked the fuse by the power cord and it is not blown. Any ideas?
    Top Expert:
  • Mitsubishi Master
  • 74,136 Answers
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Posted on Apr 25, 2013
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV won't turn on - no power
Thats the V23+ chassis. There are numerous fuses to check. There are 9 regular fuses they are F9A01,F9A02, F9A03, F9A04, F9A05, F9A06, F9a07 &F9A08. Also there is another Fuse F5A00, F9D00 and there are 2 ceramic chip fuses numbers F9B00 and F9B02. Let me know if you need further info.
Posted on Feb 28, 2008
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
Maanita
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
My 55313 mitsubishi just will not power on. green light comes on but then goes not off not ever producing a picture. ran error codes, none detected? what could be wrong? plz help
Hello.
Just in case if you have done it wrong.... To retrieve error code plug TV into wall outlet. Push power button, let it do whatever it does. After that push BOTH buttons in fron of TV named "Menu" and "Input" and hold it for at least 5-6 seconds.
Green LED in front of TV will start blinking error code (when it starts you can let buttons go).
If it clinks like "2 blinks, pause, 2blinks longer pause, repeat" most likely you have convergence issue. Two convergence amps have to be replaced along with couple PICO fuses that already open.
I would strongly recommend to let professional do this repair. As well in case of different error code.
Should cost you in ball park of $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-55313 55" Rear Projection...
No picture - blinking power light
more than likely you need to replace the lamp. Before you buy anything check the lamp to make sure.
Apr 14, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Tv will not come on
Replace Both of your STK ICS.Mats has them
1-800-628-1118
Mar 17, 2010 | Mitsubishi WS-55313 55" Rear Projection...
WS-65869 Turns off automatically after about 2 seconds
I have the same exact problem, did you guys got any help?
Jun 23, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
It will not turn on.
i have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Nov 09, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
