Question about Garden
I am looking for sevice bulletins for honda 3813 lawn tractor
Transmission has 15 to 30 second delay and a noise coming from the back of the engine
I had a similar problem with my Honda 3813. When I tore it down, I found that the 3813 has a slow delay cyclinder - something like a shock absorber - the slowly puts pressure on the clutch plate after you let up on the clutch pedal. In my case, the clutch is old and worn, this is exactly the symptom I experienced because the clutch was nearly worn out - it took like 10 or more seconds to get going. A new drive clutch and a little adjustment fixed this problem for me. To replace the clutch without removing the engine I had to cut the cross brace plate on the bottom of the tractor.
To get to this you need to remove all the tin that is under the seat part of the tractor - a real nuisance.
Also, it took me 3 months to get the clutch from the Honda dealer. .... definitely not helpful! Good thing I had a John Deere as a backup, I've never had trouble getting parts quickly for that.
Posted on Jun 30, 2009
Tractor starts and the blades turn but it does not go forward or backwards
Have you checked the drive belt for transmission, 2 belts come off engine pulley, 1 for mower deck, the other for transmission
Mar 28, 2015 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Overrevving ht 3813 lawn tractor
Check your governer linking. It sounds like it may be loose or bent.
Mar 11, 2012 | Garden
I have an 02 intrepid ES with 3.5, 126K. All of a sudden the trans dropped into 2nd when I stopped. It would not shift out of 2nd until I stopped and turned the car off. The engine light came on. When the...
P1776 is the only code you need to be concerned with it a problem with the solenoid back (not the transmission valve body) Also did you recieve the transmission reflash that the dealer are supposed to do? And this is why you are dealing with a delay engagement (by the way its not second gear its 3rd)
NUMBER: 21-004-05
GROUP: Transmission
DATE: January 22, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-007-04, DATED MAY 11, 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES, ADDITIONAL MODEL YEARS.
SUBJECT:
Transmission Delayed Engagement
OVERVIEW:
This bulletin involves replacing the front pump assembly in the transmission and checking the Transmission Control Module (TCM) for the latest software revision level.
Aug 23, 2011 | Dodge Intrepid Cars & Trucks
My 2003 honda accord 3.o engine has a code P0706 can u sent me a trouble shoting
Drive Train: POWER TRAIN:AUTOMATIC TRANSMISSION Service Bulletin Number: 11012004 NHTSA Number: 10013662 Model Years Affected: 2005 Date of Bulletin: 04/2005 Bulletin Summary: GOT AUTOMATIC TRANSMISSION DIAGNOSTIC TROUBLE CODE P0706? CHECK THE SWITCH COMBINATIONS. HONDA SERVICENEWS.
Likely yours is the same.
http://www.obd-codes.com/trouble_codes/
good luck and don't forget to vote!!!
Oct 11, 2010 | Honda Accord Cars & Trucks
Does the Honda 3813 take a positive or negative ground?
Most all garden tractors here are negative ground. I have seen only a few things positive ground, and that was an old land rover and old jaguar, Both british made. I couldn't find any reference to it being different. Hope this helps.
May 10, 2010 | Garden
Been having some transmission issue with my 2009 CRV. First off about a week after getting it, I started noticing every time i took my foot off of the accelerator it would downshift, sometimes quite...
Definitely something wrong within the transmission. Hondas have never been the smoothest shifting transmissions, especially with some miles on them. What you are experiencing is beyond that though. Get a second or third opinion from different dealers.
Mar 11, 2010 | 2003 Nissan Altima
Sears tractor mower gearshift stuck or hard to shift
If this is a standard shift transmission, try rocking the mower back and forth. May be in a bind. If not, look underneath mower and find where shift linkage goes into transmission and try to move by hand.
May 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
480 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
