Motherboard Help With a minimum cpu, cpu fan, and 1 stick memory, I get the same result: No boot, No beeps, Power LED on, Fans on. Suggestions?
These machines have all been equipped with the bestec power supplies. These are junk and are all failing prematurely. The bad thing about this is when the PS fails, 90% of the time it takes out the mother board with it. You can replace the PS, but be prepared to still have computer that won't boot.
Posted on Apr 05, 2009
    Genius:
  • 1,066 Answers
Power supply.
Posted on Mar 22, 2009
Got an interesting issue. I've got a dell inspiron 531 with a dell ry206 motherboard. Bad news is, when I boot up the pc, the power turns on, the fans turn on, but that's it!, only CD ROM and cpu fans...
Hello
Open up the case,after unpluging pc.
Remove memory sticks one at a time.After you removed one try pc again.
If it boots up normally then you know that memory stick is bad.Also check your keyboard by unpluging and pluging back in while booting up.
More then likley this is bad memory.
Mar 24, 2011 | Dell Computers & Internet
When pressing button to boot up there is no response but a beeping sound and no boot up
Count the beeps assuming that there are a certain number, and check on the motherboard manual to seewhat they mean...
Likely causes
Fan(s) clogged up- clean everything thoroughly and check cpu fan and all fans including power supply
Check power supply voltages
Memory failed, swap it out or remove 1 stick at a time if there are 2
Motherboard failed due to bulging capacitors
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Dell Vostro 200 PC Desktop
BST ATX - 250 - 12Z C7R it is a HP compaq 2290 microtower desktop..the power supply led just blinking...i tried the above procedures of unplugging and plugging of main power motherboard which only made the...
Does your motherboard have a beeper? Does it emit any distinguished beeps?
First, to locate the problem, try to boot your system with only a bare minimum of components: motherboard, cpu, ram, videocard. Try your system with a known to be good power supply. Then, if possible, try it with other known to be good components. If possible, check power supply with a psu tester or multimeter (that takes some time). Every bit of description of system behaviour will be helpful.
Feb 22, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
Hi! I get Supermicro U2 server with X5DPA-GG MBO. Cpu and memor modules are ok, but when I turn on server I get long error beep. I took manual and saw that's overheat problem (or should be). But server...
This sounds like a video controller issue. Try booting with a different monitor. Ensure the cables are connected to the motherboard correctly (fans/power/led indicators). Try booting off of a single stick of RAM. Otherwise you may need to check the warranty status and RMA the motherboard to have it repaired/replaced.
1 beep: circuits reset - ready to power up
5 short, 1 long: memory issue
8 beeps: video adapter issue
Feb 21, 2011 | SuperMicro X5DPA-GG Dual Xeon/E7501/FSB...
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
Jan 29, 2010 | Gigabyte Computers & Internet
When I turn on the power, the fans start to turn but then quit after a couple seconds.
hi,
i,d suggest CPU/Memory or motherboard Fault.
try removing 1 stick of memory, then re-boot. ( if theres 2 In )
remove the cpu fan, Check for Dust Blockage, remove CPU. And re-seat-seal-replace Fan. ( re-boot )
remove power from Case ( mains power ) remove side panel, locate CMOS Battery ( Silver coin-Cell ) On motherboard for 10 Seconds, then replace, repower and boot up.
Any of these could resolve your problems.
Mike @ Compurepair.
Nov 03, 2009 | MSI MS-6523 Motherboard
No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Dell PowerEdge 1600SC Server
Computers & Internet Logo
227 people viewed this question
David Payne
David Payne
