Question about Android Apps
Need help Ps3
Need help with my playstation 3 it not showing on my tv it's a fisher
Soz can't see hook up.
Posted on May 02, 2013
  • zebclark May 02, 2013
    soz can't see hook up.
Orange flashing light on PS3, picture on show on tv, whoever i can hear some music
Please take a look at PS3 Red Light Fix Guide -
It show you many seneraio of PS3 red light flashing problems and provide solutions how to fix it. It's a step by step guide even you are a begineer to fix it.
Nov 25, 2011 | Sony Playstation 3 (PS3) Console
Was playing rugby world cup 2011 today when some random fuzzy lines appeared on my tv screen, i switched my ps3 off straight away as i though it needed a rest and, ever since, am unable to use my ps3, im...
Please confirm which of two is at fault. you can connect a DVD using the same RCA jacks, the red and whilte for audio and the yellow for the video. If the TV works then we are clear on the TV or we need to check other inputs on the TV.
If so the PSP has encountered and error and it can be due to a memory crash after it was shut down.see if there is an error code or if this PS3 does not boot at all there is an hardware issue.
check this link for support:
http://us.playstation.com/support/?s=ps3#ps3x
Oct 28, 2011 | Sony Playstation 3 (40 GB) Console
The ps3 is on and working but will not show anything on the tv
that sounds like a connection problem. check all the wires to make sure they're connected properly. if that doesn't work, then you need to change the settings on the console itself. ie. if you're using an HDMI cable to connect to the tv for example, that option needs to be selected in the play station settings... the problem is that you cannot see what's on the screen.. is there anything else you can connect the ps3 too? or can u use the cable that came with it to connect it t the tv?
Aug 19, 2011 | Sony Playstation 3 (PS3) Console
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on but does not show on screen
There could be a few different things causing this. If you are sure that the cables are all hooked up properly and the TV is on the correct input, I'll make some suggestions. The simplest solution could be that the ps3 is outputting a signal that your tv can't display. The way to reset this is to hold the power button (not the rocker switch in the back but the button next to the eject button) for 5 seconds or so. You should hear 2 beeps. This will reset the display settings. If this doesn't do the trick and you have the ability, try a different cable. Try the ps3 on a different tv as well. It could be that the TV may need a firmware upgrade.
If all else fails you can always call Sony PS support at
1800345SONY
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} --------------------------------------------
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Sony Playstation 3 (PS3) Console
I plugged my ps3 into my friends he tv and now just have a blank screen when i connect it back up to my old style tv???? Why... please help
Have you tried this?
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
If this doesn't work, it may need to be repaired. A good place to try is www.videogame911.com. They do really fast work and save all your data.
Jun 16, 2011 | Sony Playstation 3 (PS3) Console
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
I connected my playstation 3 to another tv and it
If you attached your PS3 to an HDMI capable TV it asks you if you want to switch to HD Mode.
However, once you attach it back to a regular TV you get no picture.
Follow these steps to resolve:
1. Turn off the PS3 so it only shows a red light. You can flick the power switch in the back then back on again.
2. With your PS3 connected to the TV and the TV on, press and hold the power button.
3. Hold the power button until the screen "flickers" and then immediately release.
4. Wait a few seconds and the PS3 logo should appear.
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 not showing picture when connected,
the cable got a problem or the ps3 did...
check it out at the store
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont show or load games
If you originally set up the PS3 with A,V cables it won't work on HDMI even if you set it up to and visa versa. There is a work around but you will have to call tech support. Here is a link at Sony's PS3 tech support that may help also. http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=263
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Android Apps Logo
962 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
