Question about Exercise & Fitness
Turns on and can hear the motor going, but no movement
Have had this for a few years, but used very very little. Could there be a rubber belt that has broken or slipped off? A website or manual online on how/where to check that part out would be very useful.
    Problem Solver:
  • 12 Answers
Without make and models number can't get a manual, but it should be easy to check. Just need to remove the motor cover, (the one by your feet) there should be screws around it (3-6) then jiggle the cover it should come loose, if it does check for more screws, sometimes they put screws in from below. Once off the belt should be obvious, look at the end of the motor. (the other end)
Posted on Mar 13, 2009
Where can I find drive belt for rca rs-9150a (opens the cd door)
I have had this unit for a number of years. Can't find the original drive belt so I've been using rubber bands. They work for a while till they dry rot. If you're doing the job yourself, go to a hardware store and get an assortment of rubber O-rings for plumbing. A little tricky to get one on the gears but I put one in a few months ago and so far it's outlasting a rubber band.
Feb 14, 2015 | RCA Audio Players & Recorders
Serger repair
Lack of use is the worst thing for these machines. The grease turns to glue and freezes up from the lack of movement of any kind. Next time, move the flywheel once a month, whether you need to sew or not. This one may not be worth the repair $'s.
Cheers,
Embroidery Services
San Diego, CA
Sep 18, 2017 | Brother Sewing Machines
Hi there. I have lexus rx300. A few days ago the brake light been going on and off when driving. So i took it to the dealer, then they only said the brake fluid was low, but if it happens again then we...
If the fluid level is again low, you are losing it; if not, the level sensor is likely bad. Lost fluid indicates a failed master or slave cylinder at one of the wheels. The squealing you are hearing isn't likely from the brakes but from a belt that needs replacement or at least tightened; the fact that is squeals when starting and in turns, indicates that the steering pump being driven by that belt is slipping a little under the stress of making turns. This often goes away once the engine room is warmed up since the belt rubber gains a little grip when warm which stops the squealing.
Jul 10, 2011 | Lexus RX 300 Cars & Trucks
My Kenmore washing machine is 19 years old...Love it! But all of a sudden it fills up but won't agitate or spin, but will drain. I can hear the sound of the motor like as if it's spinning, but no...
Thanks for choosing FixYa and welcome. Check your belt first. The transmission may be bad. It may be the motor coupler. The only way to know for sure is checking it out. Are you able to run a few test?
May 28, 2011 | Washing Machines
After 14 years my Technics SL-BD22 Turntable has a disfunction The electric motor turns slow.
Your turntable is probably belt driven so most likely motor is turning okay but belt is slipping.
They are easy to change, first just lift rubber mat on platter and you should be able to see the belt through a access hole in the platter.
Feb 28, 2011 | Technics SL-BD22 Turntable
I have a Kenmore cloths washer, model #110.24642300. The other day it filled up with water and stopped working. If you try to turn it on now, it does not do anything. But you can hear a small hum or...
The belt may be in place but it appears to be loose and slipping. Probably worn out. You hear the hum because the motor is running but the belt will not let it drive. When you have it apart make sure the part the belt is driving turns by hand.
Jun 14, 2017 | Kenmore Washing Machines
I have a frigidaire washer model fws777ghs0.after the spin cycle the water is drained but the clothes are too wet.there is a smell of burning rubber.when I open the lid I could see a slight smoke.could it...
probably burned up your motor coupling! see if you can hear the motor running either on the agitate or spin cycle,if you hear the motor running but no movement then it's gonna be the motor coupling it's plastic and rubber! cost about $20
Jan 11, 2010 | Washing Machines
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Nov 12, 2009 | Nordic Track /proform Treadmill...
Exercise & Fitness Logo
315 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
