LCD in german not in english I followed the procedure mentionned by paulcrow on this website, but it doesn't work. Now, a message display "Please DL ROM". What does it mean ? Hereunder the procedure that I followed ... Please follow the instructions below to change the language to English. 1. Turn off the machine 2. Hold in the MENU button. 3. Turn on the machine while holding the menu button 4. Maintenance should come up onscreen and the lights should flash. 5. Key in the numbers 74 and press Mono Start button. 6. Key in 0004 and press Mono Start button. 7. "MAINTENANCE" appears again on the display. 8. Key in 99 at the maintenance prompt to exit to the date and time. How can restore the factory setting ? Thanks in advance.
  • 832 Answers
SOURCE: Brother MFC-410CN Ink Jet Problem
Please push menu button then start mono then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
Posted on Sep 17, 2007
  • 1049 Answers
SOURCE: Maintenance Reset
On the Ricoh 3713 you can do it on the main board by putting dip switch 101-1 on and then off, entering 97, and pressing the aps key. Then power cycling the printer.
The 3500 is probably similar.
Posted on Jul 24, 2008
  • 83 Answers
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Posted on Dec 11, 2008
  • 1314 Answers
SOURCE: Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Posted on Dec 27, 2008
SOURCE: DCP-110c is showing machine error 46. I have
Many thanks - I fixed the error 46 by following the helful solution provided below.
Rank: Apprentice
Rating: 86%, 8 votes
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Dec 14, 2009
How change language for printer brother mfc-j 5910dw to english
To help you change the display language for MFC-J5910DW Brother printer and copier, please follow the steps given below:
- Press 'MENU' on the printer screen.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Initial Setup.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Local Language.
- Press 'ENGLISH'.
- Press the 'STOP/EXIT' key.
If issue persists, please contact Brother Printer Support Center from the link given below:
May 30, 2016 | Brother Office Equipment & Supplies
Hello, you can try this simple steps configure your language in any language you want; english, german or japanese or even more! And this is the steps, kindly follow it thoroughly to changed it with ease;
1. Open your phone.
2. Tap Menu.
3. Tap Configure or Settings. (a wrench icon)
4. Tap Phone. (a phone icon)
5. Tap Language Settings.
6. Tap Phone Language.
7. Tap the language you want.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Feb 04, 2014 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Select language
go to initial set up and choose local language, then check the English lalanguage. if no English then you have to update the firmware.
Apr 19, 2013 | Brother Office Equipment & Supplies
I purchased a brother mfc-j220 24/5/12 that has the printing preferences in German. I need these to be in English as I am in Australia.What's your problem?
When you loaded the printer driver you may not have selected English as preferred language when asked the question in the driver install process
You may have to uninstall & then reinstall the printer driver
However, as a first step go to the printer icon, right clik, go to properties and see if you can fine a language choice on the printer properties Tabs / options
Jun 03, 2012 | Brother Office Equipment & Supplies
I have purchased a MFC 6490CW printer in Germany. can I change the language in LCD screen from german to english on MFC - 6490CW?
Yes under settings there will be a language option, just have to go through the process in the German Language
May 22, 2011 | Brother MFC 6490CW InkJet Printer
Hi My brother printer has changed to german language from english how do i get it backn cheers Greg
All brother manuals and software is available for free download from their website - go to, and select your country.
Oct 29, 2010 | Brother Multi-Function CenterĀ® MFC-215C...
How do you reset a Brother MFC-7840W printer to factory default settings?
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
Dec 08, 2009 | Brother MFC 7840W Printer
How to change instructions from german to english brother printer cfn620cn
Keep navigating through the menus on the printer's LCD screen.
Open your web-browser to:
which lets you type in text, in German, and Google will translate it to English (or Klingon), so that you can read each sub-menu, and make the correct "click" to reset the printer's language.
Nov 20, 2009 | Brother MFC-620CN All-In-One InkJet...
How can I change the language?
if you go to the brother web site update your drivers and select the language you want in the process
Feb 08, 2009 | Brother MFC 9050 All-In-One Laser Printer
Change LCD language to English on Brother MFC-3240C
Gud Day!
Dec 11, 2008 | Brother MFC-3240C All-In-One InkJet...
55 people viewed this question
