Question about Bunn BT10B Coffee Maker
Water doesnt heat anymore
Is it worthwhile fixing
I think i damaged something with the hairdryer while trying to thaw my water in the door
An overheated solenoid will only affect the ice dispenser not the water section so we can rule that out. I would render a guess that the dispenser paddle is broken or melted. This would prevent the microswitch from making contact with the paddle. Replacing the paddle should fix the issue but you will have to verify.
I assume you have a GE fridge based on the frozen water line issue. Instead of heating the area with a hair dryer i have had great luck with this little trick. Purchase a container of "zoom spout oiler" which can be found on amazon. Empty the oil into a suitable container and flush the residual oil out with water. Next time it freezes fill the zoom spout oiler with hot water and extend the nozzle inside the frozen line and squeeze. I also disconnect the water line behind the kickplate under the freezer. Lock the dispenser so you don't accidentally pour water on your floor. Put a towel on the floor and when you clear the blockage at the dispenser water will flow onto the towel. Hope this helps you with your fridge!
May 04, 2017 | Refrigerators
If i put rice nd water in rice cooker. It doesnt cooj.it will b as it is.lamp wo t glow.vessel doesnt produce steam
The thermal cutoff blew (it is like a fuse) either but another one, or attempt to purchase a part from an electronics supply and replace it yourself. If you can locate an appliance repair place they charge to much to make it worthwhile.
Sep 22, 2013 | Kitchen Appliances - Others
Roper dryer red4400sq0
The heating elements and the motor would have gotten wet with that much water. You need to disassemble it and check both.
Jul 07, 2013 | Whirlpool Dryers
Doesnt seem like water is heating and element not getting hot
Sounds like you checked the basics. Do you have hard water? Our element got covered with calcium over time and didn't heat efficiently anymore. I was able to chip some off, then ran the dishwasher with LemiShine a few times. The element worked much better after that.
Dec 17, 2012 | Frigidaire Professional Series 24 in....
It powers on but it doesn't heat up anymore!!!
sounds like your element is bad, or is not connected
Apr 23, 2009 | Wolfgang Puck Rotating Waffle Baker -...
Electrical issue
doesnt sound good...i would have the body control module tested
Nov 03, 2008 | 1997 Oldsmobile Aurora
Won't heat water anymore - only washes in cold water
u need to take the back half panel off once off u will see the two thermostats and the heater element you can test the element by undoing the wires and getting an old wire with plug on 1 end and bear wires on the other place corrisponding wires to were that wire had come of turn plug on and if it is working it will heat up straight away which means the thermostats need replacing if it doesnt then the element needs replacing
Feb 07, 2007 | Zanussi FLA1001W Front Load Washer
Bunn BT10B Coffee Maker Logo
22 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
