Question about HP Pavilion dv6000z Notebook
No sound from internal speaker Hp laptop
Hey everyone its my first time posting here.. and I do not speak English very well but I know you guys can help me. I bought a dv6000 hp laptop with windows Xp in the USA. One day of those I was listening to music trough my earphone and after I unplugged it I could not hear any sound from my internal speaker. Only from the headset. Ive searched everywhere on internet and I could not find any solution to my problem and I would be glad if anyone could help me.
  • 1 more comment
  • br_dude Mar 13, 2009
    I've already checked the sound settings and reinstalled the audio driver and update the bios. I had this problem before  and I system recovered my pc. The sound came back but I used the earphone again and unplugged it and the same thing happened so I recovered the system one more time and it did not solve my problem.
    I have no problem with my powerbutton  and the quickplay touchbuttons work fine.
    I'm sorry but I did not understand what you meant with "But since this happend after you used the audio pass through board, that is the most likely cause. If you are comforteble opening the notebook, you can check this by disconnecting it. If the sound comes back on the internal speakers after disconecting it, it will need to be replaced."
    Disconnect what?
    Thank you so much for your help!
    I tried opening the computer but I was not really sure of what to do so  I will take it to a repair store. Thank you for your help.
  • looly015 Mar 26, 2009
    the sound doesnt work on my laptop and really want it to can any one help e for as i have only had my laptop a few months and i like to listen to music on it. my sound was working fine right up until the laptop was set back to factory settings if any one as any ideas then can they email on this address
    chelseahamlin@live.co.uk i will be greatfull if some one could get back to me thank you very much
    i do not have a manual so i can work from that thank you once again
    Problem Solver:
  • 15 Answers
I recomend you check the soundsettings for output devices in the controlpannel first, and try reinstalling the audio driver and updating the BIOS. If you want to be 100% sure its not a software problem you can also a full system recovery. You can start it by pressing F11 at the HP logo during boot.
Else, if the powerbutton does not light up(it should when you turn on the unit) it is a defectice PBB cable. But even if it lights up it doesnt rule out that the cable is defective. If the quickplay touchbuttons are sett to give a beep when pushed, you should check if they still do. if not it strengthens the probability of the defective cable.
This can also be a defective mainboard. But this is a very rare mainboard problem on these models.
If the unit is out of warranty and you want to replace the parts yourself, I can provide you partnumbers. But i will need the modelnummber form under the unit. It should be written on a small whtie lable and look something like this AA111BB#CCC.
Posted on Mar 13, 2009
  • ShinyTechie
    ShinyTechie Mar 13, 2009
    The "audio passthrough board" also known as "Audio/IR board" is the circuit board in front of the mainboard with the audio connectors.
    The problem might be related to something shorting in this board. Causing the unit to think there is a headsett connected, and disabling the speakers. So disconnecting this board would stop the shorting, and the unit would act as if no headsett is connected and enable the speakers
    again.
  • ShinyTechie
    Here is the servicemanual. If you go to page 3.2 you can se it. Its part number 15. I dont know if this is the exact same model as you have, so I dont know if the partnumbers will fit your unit.
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Skype cant hear me
yes sir,you need to have a microphone, i believe there is a microphone port on you computer..
Jun 24, 2008 | HP Compaq Presario V2000 Notebook
No sound in speakers
Sometimes the speaker internally disables itself when another audio device is connected (i.e. headphones or external speakers) and need to be reenabled from Control Panel. Try this.
Mar 07, 2008 | HP Combo Case HP PAVILION Speakers, Mouse,...
Speakers inop. on kenwood reciever
The speaker protection circuit sounds to be engaged. This protects you speakers form damage if a fault condition occurs inside the amp. Generally speaking, unless you have good experience at fault finding electronics, then this may be a job for a repair guy. If you want to know more about diagnosing the problem, get back to me here. Good luck :)
regards
Graeme
Feb 15, 2008 | Audio Players & Recorders
Using Skype - Intneral mic no longer works
Its due to your internal laptop MIC's failure! Plz check at any Compaq Service station! Becoz its internal hardware error! Becoz there r no seperate drivers for MIC! If your speakers are working great then MIC should work or else try to get repaired it!
Dec 02, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion dv6000z Notebook Logo
1,164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
