Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Control lock it will not stay latched
    New Friend:
I have this same problem. Any fix? Can I buy and install a new latch? Will I have to remove the entire door to access it?
Posted on Feb 06, 2014
CONTROL LOOK STAYS ON
This usually means you have a problem with the door lock/latch assembly. Replace it with the part linked below.
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Door-latch-lock-item-number-AP3837611.aspx
Nov 25, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a self cleaning oven, I tried to set it to clean, it locked but did nothing else. It would not even release the latch to open. We did get it open but the latch did not retrack. It was forced open...
Your lock motor may be jammed and that's sending the wrong signal to your electronic control. Usually just replacing the lock motor is sufficient, but in rare cases the control needs to be replaced too.
Dec 16, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | LG WM1814CW Front Load Washer
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Samsung CLX3160FN: scanner stays locked
Hi Stijntje,
The scanner lock is actually a physical locking mechinism. It is not a control panel option.
the scanner is locked in a safe position before they ship the unit to prevent damage to the scanner.
I believe that this sliding latch can be located ( while looking straight at the unit ) on the under side of the scanner, above the area where the paper comes out, more to the left hand side.
locate the latch and slide it from the locked position to the unlock position.
Press stop/clear button to clear the error and try again.
Good luck,
Oct 11, 2008 | Samsung CLX 3160fn All-In-One Printer
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
95 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
