Question about Honda Garden
Change cutting deck belt on honda hf1211 - Honda Garden
  • Anonymous May 15, 2015
    Does anyone know how you go about this please?
2 Suggested Answers
  • 407 Answers
SOURCE: The cutting deck is so unstable & the belt drive
For the deck,they do move it allows them to cut evenly on uneven surfaces.Lower the deck and inspect everything on top of the deck.These mowers have several arms to hold it in place.Make sure none are disconnected,or have broken clips.Make sure to wiggle each of the arms,some times they can fall in a position so that it looks like that is where it belongs.
As for the drive belt.Just keep the mower out of the weather as best as you can.Feel the pulleys for burs,and make sure there is no debris hanging that may be scrapping the belt.
Posted on May 14, 2011
Huskee 26 hourse power 54 inc deck/how do i change both drive belts on this tractor
The one on the deck you will have to remove the deck. Flip it upside down and replace. There will be an idler wheel with a spring on it that allows you to release tension as you put the new on. The drive belt comes from the front of the motor and loops underneath to the cutting deck. There will be a point on the deck that you can get a little wiggle room to move it forward to get the belt on.
May 01, 2016 | Garden
How to change belt on 54inch cut husqvarna lawn tractor model yth2454
Which belt? The cutting deck belt or the belt which drives the mower?
Jul 07, 2014 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
Lawn mowres
Can't find one for you. Do you have a manual, may a diagram.
Apr 19, 2014 | Garden
How to fix Honda HR215 mower from skipping grass
check the belt tension on the deck
Apr 22, 2012 | Garden
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
447 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
