Question about Garden
How to fit cutting deck belt to honda hf1211 - Garden
3 Suggested Answers
daneinwv
  • 124 Answers
SOURCE: I have a Husqvarna LR121
My name is Dane and I am going to help you solve your problem. Below is a link to the repair manual for your mower. You will find diagrams and everything you need there.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=lr121&types=O
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 09, 2010
  • 407 Answers
SOURCE: The cutting deck is so unstable & the belt drive
For the deck,they do move it allows them to cut evenly on uneven surfaces.Lower the deck and inspect everything on top of the deck.These mowers have several arms to hold it in place.Make sure none are disconnected,or have broken clips.Make sure to wiggle each of the arms,some times they can fall in a position so that it looks like that is where it belongs.
As for the drive belt.Just keep the mower out of the weather as best as you can.Feel the pulleys for burs,and make sure there is no debris hanging that may be scrapping the belt.
Posted on May 14, 2011
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
It shut offs
Questions for analysis:
How old is this machine?
What is the condition of the walking belt and deck?
(most problems with treadmills cutting off during use stem from worn walking belts and decks - replacement is always recommended unless unit is less than 1 year old)
If you are able to walk on the edges of the walking belt (away from the center of the deck), run a test to determine if unit is still shutting off. If not this may be another indication of excess friction in the center (walking) area of the walking belt/deck. The only way to be accurate about this test would be to perform an amperage test, testing the machine unloaded, with load at 3mph, and with load walking on the edges of the walking belt
Nov 25, 2013 | Life Fitness T5-0 Treadmill
How to fix Honda HR215 mower from skipping grass
check the belt tension on the deck
Apr 22, 2012 | Garden
I have a MTD 0675 g Ride on mower, with a 18hp Briggs IC engine. I have recently re bearing'd the cutter deck and fitted a new belt. I cant work out how to adjust the belt-tighten it a little as it slips...
check to see if the belt is in the correct routing, most belt tensioners are able to be fitted with a factory belt in a couple of different routing methods, however only one is right to keep the belt from slipping, look for a belt routing diagram on the mower deck they are the best source fot this information.
Jan 07, 2011 | Garden
Need to fit belt that turns blades on husqvarna lt 120 can you help.
You will have to remove the cutting deck from under the ride on to have better access to the belt
If you take a picture of the cutting deck once it is removed it will assist you in putting it back together.
To remove the cutting head belt from the engine bottom pulley you must push the foot pedal down and lock it in place to take the pressure off the belt to remove it from the pulley.
There is most probably a rod that hangs down close to the side of the pulley which is there to stop the belt from coming off when the pressure has been taken off the belt, you have to loosen the rod retaining bolt and move it away from the side of the pulley to get the room to remove the belt, there will be a cable that adjusts the deck cutting height which has to be removed from the cutting deck to be able to remove the deck, there should only be 3 anchor points that hold the deck under the mower, 2 on the sides and a steel rod throught the front with spring clips on them for quick removal.
when the deck is out you will see t hat both the belt pulleys on the deck have plastic guards on them which have to be removed to be able to get the belt off the pulleys.
Replace the belt and install all the parts in the reverse order that you removed them in.
Is a reasonably large job for a person who has never done it before but it is a job that anyone can do if they just take their time and also a few pics before removing just for a reference
Hope this helps
May 12, 2009 | Garden
Garden Logo
671 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
