Board games game works fine. but there is a big screen that appears on every screen cant see the guess who board and it stays super imposed on every screen till the end.
Well it sounds like those 2 game packs might have something wrong internally or the battery that saves your game data is either dying or is dead then. So you. Could buy new game packs to see if it works. Luke games
Well maybe that they are bad gamepacks then like the intenal parts to the gamepacks have glitches because that they are old then and broken. But the worse possiblity would be that your super nintendo is on its way out so buy stuff from reputable sellers like lukie games or jj games then.
hopefully you already figured this out but that usually just means you put the game in slightly wrong. the games can get touchy in their old age, happens with pretty much all my GBC games I have now. just try blowing in the open end of the game, insert it again and hope for the best. keep trying, it'll work eventually.
It appears that your power supply is fine (you still get a power light) however your internal game board has a problem. I realize you said that you have eliminated all the other components (very smart process of elimination) so the only thing that has not been swapped is the console itself. I think you've already come to the conclusion that the N64 needs to be repaired, and you just need to hear it from someone else. Unfortunately, the console needs to be repaired. Again, you did a great job isolating the problem, so you've done all the hard work.
1.) New Game - its your system. Super Smash Bros is a dual layer game and it takes a strong laser to be able to read the game. You would need to get your laser replaced.
2.) Used game - possibly worn out. Check the back for scratches.
it sounds like your tv is being classified as insecure (some older models of hd tv as well as regular tvs do not always pass the "test" but will "pass it" on certin other occasions) it means that the ps3 may have determined that the tv can be used to rip the disk, if you are using hdmi try switching to s-video or composite. my ps3 did the same thing. I will try to remember how to fix it. untill then you can try my solution or try sombody else.
I have played and beat this game and it should only last a total of 3 seconds max. Im guessing if the disc is damaged it will be longer but not to much. Theere isnt much you can do but return the game and get another disc.
Hi . i have had this sorta problem when i play the resident evil game. I find that if you go to your menu on your startup screen and change the screen resolution it should work. some games require certain television res to allow play.
