Question about Canon imageRUNNER 3035 Black and White Copier
Canon 3035 missing drawer options
I have a Canon 3035. The print properties did show drawer 1 - drawer 4. Now I only have drawer 1 and drawer 2. How do I get drawer 3 and drawer 4 as options to print to? Thank You in advance for your help.
  • weddle641 Mar 14, 2009
    Thanks so much you really know your stuff!!!
  • 318 Answers
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Posted on Mar 13, 2009
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Canon mg2520
This is usually a Word option.
In Word versions prior to Word 2007:
1.Click the Tools->Options menu item.
2.Select the Print tab.
3.Make sure Include with document/Document Properties is DEselected.
4.Click OK.
In Word 2007:
1.Click the round Office button in the upper-left corner of the window.
2.Click the Word Options button.
3.Click Display.
4.Under Printing Options, uncheck Print Document Properties.
5.Click OK.
Jul 22, 2014 | Canon PIXMA MG2520 Inkjet All-in-One...
How do i clean the printhead on my pixma mp750
If you open the preferences option for your printer there should be a maintenance tab with easy options for cleaning and checking the results. The alternative is to use the menu directly on the printer: 1. Press Menu twice to show "2. Maintenance" 2. The first option is NOZZLE CHECK 3. Press OK This should give you a print showing the current state of each colour. If there are any missing lines in 3eBK or lines in any colours then perform the head cleaning below. 1. Press Menu twice to show "2. Maintenance" 2. Press + to show "CLEANING" 3. Press OK Repeat the nozzle check after each clean. If not improved after three attempts try a deep clean as below (cleaning uses up ink) 1. Press Menu twice to show "2. Maintenance" 2. Press + twice to show "HEAD REFRESHING" 3. Press OK Repeat the nozzle check. If still not printing correctly there are various external solutions available to clean the print head such as http://www.printheadhospital.co.uk/canon-hp-printhead-cleaning-kit.html
Oct 17, 2012 | Canon PIXMA MP750 All-In-One InkJet...
HOW DO I SECURE PRINT ON MY NEW M3035 MFP PRINTER
The 3035 supports a pin printing method. This is done from the print driver. Start a print job as normal, if you have Word or Exel you cannot use the quick print option. Once the print window opens, click on properties which is right next to the printer model name. then click on the job storage tab, select stored job in the job storage mode mode and click require pin and enter the pin number you want to secure the job with. The driver will default to using our windows username as the username that your job will appear under on the control panel of the printer.Click ok and then complete the print job as normal. Then go to the 3035 and select job storage from the control panel options and follow the steps to retrieve your job.
If you are searching for even more secure methods, Cappella Technologies makes a product that will encrypt the data stream between your computer and the printer.
Feb 10, 2011 | HP LaserJet M3035 MFP Printer
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
Canon ir3300 not communicating with microsoft windows getting error: printer load paper but trays are full. Can you help?
Under printer properties check the format of paper, it must be A4 if you have A4 in drawer. The most common fault is that under printer properties is LTR as format and A4 in drawer.
NOTICE: in paper drawer did you check the little blue wheel, is it "telling", the appropriate format as in the drawer?
Jan 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Stapling from the print mode
Yes, look in the printer properties in control panel to set this option before you print.
Nov 19, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Legal size paper on LBP-1210
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
Printing from Other Drawers
this is the link to the manual if you need it http://publibfp.boulder.ibm.com/epubs/pd... page 47 shows how to manually describe the paper type in each tray - after that, when printing click on properties and select paper type - it should automatically select the correct tray - if you want the same paper in more than one trays, it will always use the first one first, then start using the others. Hope this helps :)
Mar 08, 2007 | IBM Infoprint 1332 Laser Printer
Canon imageRUNNER 3035 Black and White Copier Logo
407 people viewed this question
old marine
old marine
