Question about Technics SA-DX930 Receiver
No sound from front or surround in tv mode - Technics SA-DX930 Receiver
Can't get surround sound sound through tv mode, have sound only when cable box mode is on. I've tried hooking optical cable straight from receiver to tv and I've also tried AV jacks. Not sure.
The audio signal that your tv is producing is a stereo signal only - not surround. You should be able to manually put your receiver into a surround mode when using the tv input and get surround sound that way.
Sep 23, 2016 | Audio Players & Recorders
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
LHB953 Theater System: switches to "auto" video mode while watching netfl...
we had the same problem and we hooked the fiber optic cable into the back of the satellite or cable box and then into the back of the surround sound system. we had it first from the tv to the surround sound and only our front ones worked when it was like that
May 17, 2010 | LG LHB953 Theater System
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
No surround sound in tv or vcr mode
For some reason this Panasonic unit does not offer surround sound in TV or VCR mode.  I guess their engineers decided it wasnt an important feature!!
Oct 21, 2007 | Panasonic SC-HT730 System
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
Technics SA-DX930 Receiver Logo
27 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
