Question about Apex Digital AT2014DV 20 in. TV/DVD Combo
Unlock tv and where is function key - Apex Digital AT2014DV 20 in. TV/DVD Combo
My sintech tv shows key lock and I lost my remote
Without a remote control; you can't unlock it.
Mar 15, 2015 | Televison & Video
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
Apex tv is locked up. The original remote is so old the numbers & letters are rubbed off. Everything I read said push the function key & mute. to unlock it, I cant tell which key on the remote is...
Maybe you can blow up a picture of the remote and see which button is function or you can order it. Here is the link:
http://www.replacementremotes.com/store/prodthumbs.cfm?ns=1&keyword=at2002s&category=All+Brands%2FType+brand
Jul 10, 2011 | Apex Digital AT2002S 20" TV
My apex tv model AT2708S is locked and i can't find manual
CHILD LOCK The Child Lock feature prevents unauthorized viewing of the TV. To activate, press and hold the F key, and then press MUTE. You should see a key symbol appear on the screen. This will lock out all remote functions (except for Standby). To unlock the TV, press and hold the F key and press MUTE. This will unlock the TV. Please note that the only way to activate or deactivate the Child Lock feature is via remote control - please insure that it is stored securely.
Aug 20, 2010 | Apex Digital AT2708S 27" TV
How do i unlock my t.v my t.v is blue
Apr 17, 2010 | Apex Digital AT2708S 27" TV
I have a older Apex 27" TV. It shows a Locked Key on the screen. How do I unlock it? Thanks
On the original tv remote hold down the "F" (Function) key and press MUTE at the same time. This will unlock the TV.
Good Luck....
Jan 22, 2010 | Apex Digital AT2702 27" TV
Unlock tv
i have a shinon tv and it is locked what do i have to do please
Mar 16, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
How to unlock my Apex TV #at2002 with only KEY shown in the corne
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels..
Please rate this Fixya solution
Jan 20, 2009 | Apex Digital PF2020 20" TV
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
KLH TV Problem
Hold the function key and mute key at the same time.
Dec 19, 2007 | KLH 13" TV
Apex Digital AT2014DV 20 in. TV/DVD Combo Logo
26 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
