Question about Freezers
MSF Controller RSRVC 164s254 14 - Freezers
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
My Freezer does not maintain the right temp. It wont maintain my food frozen.
The thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Msf-49nm will not stay below freezing!!
My next question is, you say you have to call a tech to come out. Is he doing something? And if so, what? With the limited info I have at this time, it sounds like there may be a refrigerant problem. Let me know so we can continue. Am looking forward to resolving this.
Jun 02, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Msf-49nm evaportor pan and drain iced up
I deal with MasterBilt which is a private lable made by TurboAir.
I have several units but only one does this icing up thing. Look for a bad seal on the door gasket. These really ice up if that does not seal almost perfectly. Look for premature termination of the defrost cycle. Check that the heater is pulling amps. The wiring diagram at "turboairinc.com" is very poor but it shows 2 heaters for the refrigerator. They list a diagram for the freezer but it's not there. I know for sure that there is a heater for the evap but don't know about the drain. I've seen some have it and some don't. there tech support line has much to be desired but it's worth a shot. Also, the bottom hinge on the door fails fairly regularly. This allows the door to drop just enought to disengage the switch at the top of the door and stop the evap fan from running, thus causing a freeze up.
Good Luck . You got your hands full with this one.
Dec 11, 2008 | Turbo Air 49 cu. ft. / 1388 liter...
Freezers Logo
251 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
