Question about Neff K3965XO Side by Side Refrigerator
Fridge not staying cold enough
Hi, I have a neff k5614x4gb neff intergrated fridge that is not staying cold. with thermostat on setting 5 it will come on and get down to freezing very quickly. but it wont come on again until the fridge has reached 8c. is this normal? i feel it should cut in sooner.
2 Suggested Answers
SOURCE: neff fridge too cold
Neff have just said to me that the most probable reason is the seal not being tight enough
Posted on Nov 25, 2008
I have a Neff fridge and Freezer Model K4204x6GB03. The fridge is getting very cold and building ICe on the back wall of fridge and too much Ice on the bottom of the fridge under the vegetable tray
First, try turning down the temperature control on the fridge incrementally and see if that gradually over time helps. If not, you may need to unplug the fridge for 15 or so minutes, hope it will recycle and then plug it back up, setting the control to what would be normally considered to be a moderate setting. If that fails, call a fridge repairman who you trust, , ,
Jul 28, 2017 | Neff Refrigerators
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Fridge too cold
Return your thermostat to 5 setting. If this does not help, it is probably the contacts inside the thermostat are welded shut and needs to be replaced. You can find you replacement thermostat with your model number on Searspartsdirect.com.
Sep 25, 2014 | AEG Refrigerators
Calibration screw fridge
Try the thermostat on it's lowest setting first. If it doesn't switch off soon enough and gets too cold, you can get different thermostats from your supplier. A bottle fridge thermostat would suit.
Apr 21, 2012 | Whirlpool Refrigerators
MY intergrated NEFF fridge is not getting cold. I have power (as the light comes on) but it does not seem to be chilling-what could this be?
If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Mar 30, 2011 | Neff Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Neff fridge too cold
Feb 09, 2008 | Neff Refrigerators
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Neff K3965XO Side by Side Refrigerator Logo
57 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
