Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Won't start The weedtrimmer set up for about 8 months. I poured the old gas out and re=filled with fresh. I started it fine then used it for a few minutes. Killed the engine an d put it back in the shed planning on more extensive use on the weekend. I got it out and it will not start, PERIOD. I checked the spark plug wire, put fresh fuel in it again, cleaned the air filter and it still will not start. Thoughts?
  • Craftsman Master
  • 7,482 Answers
Hi Billy
Once you poured new gas into the tank, you may have lossened some debris and it is now in the carb jets.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 25, 2013
  • Billy Moore Apr 25, 2013
    Thanks Bud....this will certainly get me started on a "weekend" project..Billy M.
    Bud...I don't see a way to "rate" your help and solution? Billy M.
wadingriver
  • 2095 Answers
SOURCE: not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Posted on Aug 08, 2012
hunter19_46m
  • 7482 Answers
SOURCE: mower will not start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
SOURCE: old craftsman pull cord
Your carbs main jet is blocked most likely.
Take the carb bowl off and look at the bolt near the top of the threads.
You should see a very very small hole. If you can see through it you need to clean it with a fine strand of metal wire.
Also work the float up and down to make sure it isnt stuck or unable to flow when the float hangs free.
Put it back together and try it out!
Good luck and be careful!
Posted on Aug 03, 2010
daneinwv
  • 124 Answers
SOURCE: I have a Craftsman 625
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 04, 2010
marc_uhrey
  • 72 Answers
SOURCE: engine won't start oil level is good has fuel
Remove the spark plug and attach the plug wire to the top of the plug. Place the base of the spark plug against a metal part of the engine and pull the starter cord. You should see sparking between the plug electrodes. It helps to do it in a dark area, not out in the sun.
If there is no spark, something may be shorted out, a wire broken, or the magneto has come apart, etc.
If there is spark, then the problem is fuel related. The gas may not be getting to the carburetor, or the air / fuel ratio is wrong, not allowing combustion.
You have to eliminate each of the possibilities one by one. I would recommend buying a can of starting fluid, which you can get at parts stores, Walmart, Target, Shopko, etc. Spray a little in the carburetor or directly into the spark plug hole. Replace the plug and if it acts like it is starting, then dies, you know you have good spark and the problem is with the fuel or carburation. If the machine has sat for a long time with stale gas in the carburetor, it gets gummed up and will not start. The carburetor will have to be removed and cleaned.
Posted on Jul 14, 2011
Piaggio fly 50 4t
Re-set the idle adjustment screw on carb? Also check fuel / air filter.
Mar 22, 2014 | 2012 Piaggio Fly 50 4V
Suzuki 650 savage won't start
dump all the old gas out, put in fresh stuff, sometimes you gotta change the spark plugs as well.
cheers bucky
Feb 20, 2013 | Suzuki Motorcycles
HOMELITE 4618C CHAINSAW WON'T RUN
How long has the chainsaw been sitting? How long has it been sitting with the same gas in it? Typically, most chainsaw and weedtrimmer repairs are fuel related. More times than not, simply draining the old gas, and putting brand new fresh mixed fuel just purchased from the gas station will fix most non start problems. Many people will not believe me, but after 20 years of fixing small engines, i've fixed 70% of the chain saw and string trimmer and related sized engines by putting in new fuel. Fuel goes bad now a days in 30 days. So if the fuel in the gas can sitting in the garage is older than 30 days it is old when you are considering trying to use it in a small engine. Fuel in a car will not cause the same issues as quickly for several reasons. If the fuel in the gas can is older than 30 days get rid of it. If after changing the fuel out completely doesn't fix your problem, feel free to contact me and I'll see if I can help you out.
Sep 02, 2012 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Car won't start then exhaust fumes smell like varnish
Drop the tank remove all fuel replace the filter and fill with fresh gas
Sep 02, 2012 | 2003 Jeep Liberty
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
I have a Husqvarna 235 that decided it didn't want to start anymore. It's only a few months since I got it. It was used the cut up a small tree that fell down in a wind storm and used again while...
Has the fuel been in it since you last used it? if so drain and re fill with fresh fuel oil, work the primer plenty of times to flush the old fuel out, crank the engine twice only with the choke out, then push it fully back in and crank again until it fires up.
Jun 08, 2011 | Garden
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
2004 rmz 250 wont kickstart, but will push-start
Kick starting is sensitive to fresh fuel. Tank should be completely drained
May 23, 2009 | 2005 Suzuki RM-Z 250
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
290 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
