Question about Compaq 32X IDE CD-Rom Drive (opal) (179959001)
CD ROM CR-589
I have a Compaq CR-589 32x CDRom drive When I inserting a DVD RW with an autostart feature, my machine doesn't read any. Please help me- may be this divice doesn't read DVD RW at all?
    Brigadier General:
  • 6,966 Answers
Hi, A couple of possibilities: With a known good DVD with files inserted into your Compaq CR-589, double click in your My Computer, double click in your CD/DVD. 1. If it opens and displays the content, then there is nothing wrong with your DVD but the auto start feature of your OS was disabled, enable auto start; 2. If in My Computer or in Device Manager, the DVD doesn't show up, then it can be hardware problem, IDE/power cable problem, bios did not recognize DVD device, replace if and as needed; 3. If the DVD is in My Computer but will not display the files or contents, possibly defective DVD, replace. Hope this worksa out for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 05, 2007
SOURCE:
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
Emachine EL1200 won't burn dvd's.
I researched the Emachine EL1200 and it IS equipped with a DVD burner so there is no reason it shouldn't work. Return it while it is still under warranty. There is a 1 year warranty.
If it is out of warranty (system is older than 1 year), the drive can be replaced.
Aug 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
Dvd-cdrom plays music-cd.Not dvd-cd :No Valide Drive/Disc Found
Simply change the ROM to DVD RW drive since this is an old PC and now days nobody uses a dvd rom but a dvd writer. It will be worth it since it can do all the functions and is also more hardy........sodeep
Apr 29, 2009 | Compaq Presario 7599 (173952-004) PC...
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Apr 23, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Insert a disk
How many CDROm drive installed on your PC? The message appear when you burn a CD or just only reading the content?
Mar 02, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    238 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Thomas F. Schneider
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
