Question about Vocopro Bravo Pro 160 Watts Digital Key-Control CD / CDG / Cassette
CD DRAWER KEEPS OPENING AND CLOSING ON ITS OWN
CDS WILL NOT PLAY. DRAWER KEEPS OPENING AND CLOSING WHEN POWER IS ON
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
NAD C521 CD Player It will not play my CDs. The CD drawer closes normally with CD in place but after a pause, the drawer opens again. There is no 'no disk' warning. The 'no disk' warning does appear...
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Sep 07, 2009 | NAD C521 CD Player
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Cd drawer keeps opening and closing
Hi, Well i had the same problem with my CD drawer.Your CD drawer has some problem. Either repair it or buy a new one.
Thanks1 Sandy
Apr 21, 2009 | Gateway GT5220 PC Desktop
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' jay_win2002@yahoo.com .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Does not play CDs. After closing, tray immediately opens again and displays "Take CD out". Cycles through trays and gets stuck.
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Jan 13, 2006 | Panasonic SC-AK600 CD Shelf System
Vocopro Bravo Pro 160 Watts Digital Key-Control CD / CDG / Cassette Logo
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
