Computer will not see sound card at all - Computers & Internet
  • 3,799 Answers
Remove it then. A new one will only cost about 10GBP. Or move it to a different slot in the tower.
Posted on Apr 24, 2013
  • nina lomax Apr 24, 2013
    I've tried every slot, it still doesn't work. Guess ill have to buy a new one.
My grandad has bought a computer and i tryed to show him how to play a dvd but no sound was playing. I found out there was no sound card? I dont actually know what this means but surely a computer should...
If there is no sound card. Probably it was disabled the sound and maybe there is no really sound card was installed. To make it short buy a PCI sound card, turn off your computer and install the card to PCI slot and turn on your computer and your computer will detect that there is a found new hardware. Ignore it and insert the cd installer and install the driver of your sound card. If it's ask you to restart just restart your computer to update its system. In case that there is a built in sound on your computer check your motherboard model and search for the driver from their official website and download and install, if you download the correct driver it will automatically installed your sound and your sound will be working. Have a nice day!
Jan 07, 2011 | Acer (54.AA806.001) Sound Card
Sound
More than likely, your sound card is hard soldered to your motherboard.  Look on the back of the computer where you plug your speakers and microphone in.  That's your sound card.
Do you have a problem, why you need to find where it is?
Oct 21, 2007 | Compaq ES1373 PCI Audio Card EURPs...
My computer has no sound..i think it is not installed..i don't know how to fix it
  1. Step 1 Shut down the computer.
  2. Step 2 Unplug machine from the surge protector.
  3. Step 3 Disconnect all peripherals from the computer.
  4. Step 4 Remove the cover of the chassis and lay computer on its side if it is a tower.
  5. Step 5 Ground yourself to the computer. If you have a grounding strap, put it on and follow its directions. Otherwise, ground yourself by touching a metal part of the chassis.
  6. Step 6 Remove the back panel, if necessary.
  7. Step 7 Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly.
  8. Step 8 If the computer doesn't already have a sound card, find an open slot.
  9. Step 9 Knock out or unscrew the metal plate on the card's slot holder on the back panel.
  10. Step 10 Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card.
  11. Step 11 Connect cables from the CD-ROM drive to the sound card.
  12. Step 12 Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole.
  13. Step 13 Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports.
  14. Step 14 Turn on the speakers and restart the computer.
  15. Step 15 If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel.
  16. Step 16 Play music CD to test sound card.
  17. Step 17 Shut down computer.
  18. Step 18 Replace cover of computer. Reboot computer.
Aug 16, 2010 | Computers & Internet
I have no sound can you help on this
Hi!
You never mentioned if you are using a built in on your motherboard or a sound card hardware...
Anyways... If you are using a built in sound card, make sure it is enable on your CMOS/BIOS setup.. And you have installed the right driver for your sound card from the cd driver of your motherboard...
And if you are using a pci sound card, please check if its properly seated on the motherboard (better if you disconnect the sound card from the motherboard... clean its contact point... and insert it properly on the motherboard)...See the model of your sound card... download the latest driver from the internet and install it.
If this still did not work, better check on the device manager if the sound card is properly installed, if its not it should have a yellow question mark attached to the sound/multimedia devices..
You can also check if windows xp keeps on detecting windows compatible sound driver..how? first, shutdown your computer.. disconnect your sound card from the motherboard...turn on computer..Right click on My Computer and click properties...Select Hardware and click Device Manager...on the View menu click devices by type...double click the "sound, video and game controllers"....if you don't see from the list the model of your sound card, then try disabling or uninstalling the listed audi driver and or multimedia devices..shutdown your computer..
Now connect your sound card to your motherboard.. turn on the computer..System will detect and add new hardware for your sound card.... install the driver... restart your computer and hear if it makes a log on sounds..
Hope this instruction help you.
Much appreciated if you rate this solution.. thanks..
May 26, 2010 | Audio Players & Recorders
How to installsound card
Assuming this is a store bought card...
Put the card into one of your computer's PCI slots
Install the driver your product came with
or
Go online to the manufacturer's website and find the driver there!
Apr 10, 2010 | Computers & Internet
Audio card
audio card enables your computer to play music with headphone. todays computer have inbuilt audio card in them.however if your computer don't have in built one ,or u want to upgrade your sound playing capabilities of your system, u can install it.
There are basically 3 types of sound card in your system
1.audio (sound)card in *********** board
2.internal
3.external sound cards.
mother board sound card can't be removed.
However u can install internal and external audio cards and dissable motherboard sound.External card connect via USB.
Apr 03, 2010 | Acer Aspire 5500 5570-2609 Laptop
Sound card cannot be detected
  • you remove sound card from the computer.
  • And again Insert in other slot.
Check the computer hope it will work. then no sound card detected. Replace the sound card or have a local tech take a look at the sound card.
Mar 12, 2010 | Computers & Internet
NO SOUND
You need to update or reinstall the driver for the sound card.Your computer manufacturer support and drivers will have your driver for the sound card if its OEM with your computer. Just enter your computer modal number find the right driver and install as instructed. If sound card is not OEM, find make and modal of sound card and get driver from them. I use driverguide.com for drivers I can't find from manufacturer.. Please rate me mysleuth
Apr 28, 2009 | Computers & Internet
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
SOUND DRIVERS
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Aug 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
472 people viewed this question
David Payne
David Payne
