Question about HP Computers & Internet
The sound is very low about 30% of what i would expect it to be, Can i do anything to increase it, thanks.
  • emyrob Mar 18, 2009
    Thanks for your help, i had already tried the solutions you suggested except the external speakers, ... this worked really well. Keep up the good work, 10 out of 10. Thanks for your time and effort it is so much appreciated,
    yours, emyrob
  • 54 Answers
Notebooks are notorious for having very poor sound quality. In order to keep notebooks small and light, very small speakers are used, which results in very quiet output, with very poor sound quality.
Before giving up, check all of your sound settings. Go to Sound from the Control Panel and make sure that everything is set where it should be. Also make sure that the master volume is turned up, as well as the volume control in whatever program is providing your audio.
Outside of that, check out some nice headphones or external speakers, whichever works better for your situation.
Hope this helps. Please take a moment to rate this solution. Thanks.
Posted on Mar 13, 2009
2002 Chrysler Town and Country rear a/c turns on and sounds like it's working, but barely blows air.
Check the air intake for obstructions like plastic bags and clogged evaporator cores.
Aug 09, 2012 | 2002 Chrysler Town & Country
How can I increase my laptop battery life?
To increase the battery operating timeline you can do a number of things. These usually include dimming the screen, adjusting the power setting to turn the screen off after 10 minutes and stop the hard drive from spinning when idle after a period of time too.
Results will vary from laptop to laptop and depends if the quoted 6 hours 30 minutes time frame is an actual recorded time of usage off ac or based on windows assumption and estimation.
Windows power management can only tell you the time in which battery power is maintainable for based on the consumption rate at the time. With this being said start up and playing games will utilise more power that say word processing after the initial startup has cooled down.
Some laptops can be operated without the battery however there are an increasing number of laptops these days being manufactured without this option. You can attempt to operate it without the battery and doing so will not damage the laptop in any way. If anything it will maintain the life expectancy of the battery.
Jul 05, 2012 | Computers & Internet
Incomig calls are exremely low volume outgoing calls have normal volume. Is there an adjustment for this
you can increase your sound by increasing the sound in profile settings.there you can find increasing sound for your ring tone.moreover you can set the ring tone that should have increased quality of your sound.then check the sound in call option.mostly samsung phones speakers have low sound quality
thank you
Dec 17, 2010 | Samsung SGH-A877 Impression Cell Phone
I have run my new IG9800 for 24hrs at 60 humidity and not a trace of moisture has collected in the tray, what's happening? Thanks Dave.
Either the condenser drain is plugged by something or maybe not even hooked up correctly from factory, of at 60 humidity there may not be any water created. This is a rather low amount of humidity. you might not be able to see anything till the humidity increases. try putting a pot of boilng water in front of the air inlet and see if this causes any water to drain. I wouldn't expect much or any at all in humidity that low. There is just not that much water in the air to begin with.
Nov 14, 2010 | Heating & Cooling
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
OIl change
For Texas I would have used the recommended 10w-40 or the hot weather 20w-50. 10w-30 sounds like cold climate or new car oil. I hope you used the Amsoil motorcycle oil with the JASO MA rating. In hot weather you might find the 10w-30 oil will tend to burn off the walls of the cylinders( some day you will check your oil and find out you are a quart low.). Without the correct rating on the oil you will also increase clutch and gear wear. Do Not use any oil that says energy conserving on the label.
May 05, 2010 | 1997 Honda F6 C Valkyrie
Removed sound card in my computer
You need a soundcard or a motherboard with onboard sound in order to hear anything from your computer.
Apr 10, 2009 | Acer Aspire One A150-1006 Notebook
Motorola Talkabout T5720 user manual
Hello cataway43,
These type of low power handhelds are good for "line of sight" communications and their range is very dependant on local geography. Over level ground with no obstructions you can expect about a mile of effective communications range, on average. If you are operating in an area with decreased line of site due to obstructions such as tall buildings or heavy vegetation then the range will be decreased; likewise if you are in an area with increased line of site (such as on top of a tall hill or mountain) you can expect increased range.
Best Regards,
"Go Ahead. Use Us."
Jul 06, 2008 | Motorola Talkabout T5720 (7 Channels)...
Model No.Samsung SGH J600
go to "settings" or "sound settings" (anything relating to sound settings or setting")
you should find volume control settings for increasing the ringtone.
if it is still low after doing through that process mybe it is time for you to change you sound speaker(they do normally get worn with constant use and would need a change)
good luck.
May 14, 2008 | Cell Phones
Not working at all
If all your connections are sound, call dell. If they can't do anything for you insist on a refund. (You have to get testy with Dell)
Dec 29, 2007 | Dell 5650 Computer Speakers
Computers & Internet Logo
214 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
