Question about Radio Communications
Can i get an operating manual
I bought it used. has hi / low channels
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model radio?
Posted on Apr 24, 2013
  • nicholsonlee Apr 24, 2013
    sorry, thought i did. it's a connex 3300-x
  • kakima Apr 24, 2013
    There's a Connex CX-3300 manual athttp://www.cbtricks.com/radios/connex/cx...
Remote control not operating
Does the remote work at all? battery low?
Jul 06, 2008 | AOC Envision L32W461 32 in. LCD HDTV
Radio Shack Catalog # 21-1926 FRS radio manual needed. Else tell me if I can change channels 1 - 7 to LO power out. Suspect they are hard coded for HI power out.
In short channels 1-7 and channels 15-22 are GMRS channels are not supposed to be operated by anyone that does not have a GMRS (General Mobile Radio Service) license issued by the FCC. They automatically run on high power. Channels 8-14 are FRS (Family radio Service) and can be used by anyone and are set to run on Low Power. The power is not adjustable with this radio. So now for the manual. Uniden made this radio for Radio Shack. So this manual is for the same radio only with the actual Uniden name. Same exact physical radio same exact manual. http://www.uniden.com/pdf/GMR1038-2om.pdf
Regards, Tony
Apr 22, 2011 | Radio Shack 21-1926
Manual
Channels 8 through 14 are low-power FRS license-free channels. Operation on any other channel requires a GMRS station license issued by the FCC. Unauthorized/unlicensed use of the GMRS frequencies can result in stiff fines and confiscation of radio equipment.
Bill B
WQJV930
Apr 26, 2010 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 31, 2008 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra MicroTalk PR-3550WX - Static after transmission
Dear sir, try to operate ur radio in different channel ,( ur operating area seems to be have so dense radio smog ..if u are located near some border where ur adjacent frequency is in use this cud be the problem .
first try in low power channel ( 8-14) ..if it solves ur problem ok ur u try to contact ur seller , & get it replaced if its under warrenty period.
Regards
raj
May 26, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
What chanel are what
D is your basic 40 channel, this is what most truckers talk on, then C is low, b is double low and a triple low then e is high and f is double high, this radio also has upper and lower side band, most ham operators use these channels. Hope its been convered to talk on CB band.
Apr 14, 2008 | Superstar SS-3900EGHPA CB Radio
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Radio Communications Logo
16 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
