Question about Goodman GMS90703BXA Heater
Flame Sensor What is the part number for a flame sensor on the Goodman GMS9 / GCS9 Furnace. I reoved and cleaned with steel wool...Still not working properly
  • 575 Answers
Posted on Apr 25, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: flame sensor on a goodman heater
The flame sensor will be located either left or right of the burners and there will be only one wire leading to it. It is positioned so the flame hits it last. So if you watch your flame spread, it will be on the side last to see flame.
Posted on Nov 11, 2008
  • 9 Answers
SOURCE: Goodman GMPN060-3 Furnace will not stay lit.has
possible faulty gas valve if all fail safes stay closed. make sure flue is clear for pressure switch to stay closed.
Posted on Dec 16, 2009
heatman101
  • 43501 Answers
SOURCE: constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Posted on Dec 29, 2009
  • 767 Answers
SOURCE: My furnace heats the house well, but during the
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Posted on Jan 02, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Posted on Jan 15, 2010
Furnace heat sensor location
clean the flame sensor with some steel wool
Jan 19, 2014 | Goodman GMS90703BXA Heater
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Flame lights, then goes right out, and heateer blows cold air.
Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 07, 2011 | Heating & Cooling
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
I have a Bryant furnace that is firing up then shutting right off.. The led is blinking green twice then yellow 4 times? What does this mean?
Feb 19, 2011 | Heating & Cooling
Hello i have a rudd furnace everything kicks on but the flames go out right away and a clicking niose comes on
Feb 09, 2011 | Heating & Cooling
Goodman furnuce cycling on lights, burner runs 6-12 sec, kicks out exuast fan runs, cycles through and does the same thing after 2-3 minutes, could this be the thermelacouple?
If your furnace has an ehxaust fan, your furnace does not have a thermocouple, it has a flame sensor. The flame sensor is a small metal rod that is in the burner area. It has one wire leading to it. Your problem seems to be flame sensor. If unit does not sense flame, it will kick off the gas valve.
Turn power off, take sensor out, (should be on 1/4" hex screw).. Probably some white film on sensor. Clean with steel wool, or dollar bill if don't have steel wool. Replace sensor.
Jan 24, 2011 | Heating & Cooling
I have a york furnace trhat when it initially ignites the flame comes on for a few seconds then shuts down. I can manually shut it off completely then restart it and most times it will come back on. I cant...
Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. I will post a pic of a flame sensor.robhvac47_6.jpg
Jan 07, 2011 | Heating & Cooling
GOODMAN GAS FURNACE. IGNITOR GLOWS, GAS FIRES FOR 3-4 SECONDS THEN SHUTS OFF..CYCLES OVER AND OVER. SOMETIMES IT STAYS ON...THEN SHUTS OFF BEFORE TEMPERATURE GETS UP TO THE STAT SETTING...
I suspect that the flame is not traveling to all the burners within a given time so the flame sensor is shuting down the gas valve. Clean out the flame rail where the flame travels and carefully brush off the flame rod with an old tooth brush.
Oct 19, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
189 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
