Question about DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker
It's not making expresso.
The motor is working. water/expresso is in but nothing is coming out
  • 575 Answers
Clogged. Check the water passage and clean out.
Posted on Apr 25, 2013
Using our coffee expresso maker for the first time but water only comes out the steaming wand
No make and no model number?? Did you read the operating instructions, you may have a setting wrong.
Oct 03, 2016 | Coffee Makers & Espresso Machines
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Apr 18, 2012 | Breville Coffee Makers & Espresso Machines
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
Water problem with Expresso maker
Well as i dont know what machine you have I will give you a generic troule shooting for manual esspresso machines.
first if the steam is working one can make the assumption that the way from the watertank to the bioler is ok.
that leaves us with the handle the filter you put your grindend beans in. Or the filter on the machine.
So first trie and see if it comes out water when you dont have on the handle with the espresson filter.
Will water not come even with the handle off? then its the fitler in the machine. trie and remove it and clean it or trie and descale it and force water through the espresso exit.
Will the water come out just fine with the filter and handle off?
then its those two things.
Trie and put the filter in alitle descaling for a couple of hours and the clean it "extremly" good.
Jul 11, 2008 | Coffee Makers & Espresso Machines
DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker Logo
228 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
