Question about Epson FX 1180 Matrix Printer
I hit the power button on my epson fx-1180 printer today to turn it on, and I got a shock from static electricity. I don't know if it's a coincidence or not, but now it won't turn on at all. I checked the electrical outlet & it's fine. The computer recognizes the printer, so it's not the computer cord. I can't find a reset button on the printer. Anyone know if it's a lost cause, or if it can be fixed? Thanks!
  • welovetogolf Mar 13, 2009
    Thank, but I tried it 4 times & the printer didn't even make a sound nor did a light come on. Darn!
  • Epson Master
  • 4,338 Answers
Check to make sure that the AC circuit is grounded properly.
Reset the printer:
To reset the printer’s EEPROM, hold down the Load/Eject, LF/FF, and Pause buttons while turning on the printer. The printer beeps once, and restores its factory default settings.
Hope this helps.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 13, 2009
  • JDTec
    JDTec Mar 13, 2009
    You may have blown the power board. It may have a fuse on it. Then it may be more economical to purchase a new one.
    Good luck,
    Joe
My X46 only turns on by the remote but when it does turn on it only goes to the Sceptre screen then powers off again. When I shut it off the night before there was a static shock when I hit the power...
That little shock has between 500 to 21,000 volts. Sensitive transistors and microchips definitely get damaged permanently from static electricity.
Jan 22, 2014 | Sceptre X46BV TV
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
I want to print using IBM BPCS but i dont know which printer choose for emulate, Im using a 6306 model.
If you r using Windows Operating system, then use Emulation as Epson fx-1180. If you r using Dos Emulation be IBM Proprinter.
Apr 07, 2011 | TallyGenicom 6306 Matrix Printer
How could we set default page setup from 11 inch to 12 inch in epson fx-2175
Dear friend,
Jus do the following:
press 2&3 button simultaneously when printer is power on.
Press itemdown (1) one time press set button 2 times
turn off and turn on pinter
Press set button once
check the print for 12 inch
Mar 11, 2011 | Epson Office Equipment & Supplies
MY EPSON FX1180 CONTINUOUSLY BEEPS, SOMETIMES 1 BEEP, 2 BEEPS AND SOMETIMES EVEN 3 BEEPS. THE PAUSE LIGHT ALSO STAYS ON WHEN THIS OCCURS. WHAT CAN I DO TO RESOLVE??
There are several sensors and switches that could be faulty or obstructed. Make sure cover is closed - would give a "cover open" indication. Check for paper stuck inside - would give a "paper jam" indication. Especially if you have ever printed labels, you may have to dismantle a bit to clear out gummy residue that acts as a paper catcher.
Feb 18, 2011 | Epson FX 1180 Matrix Printer
We have an Epson printer FX 1170, FX 1175 and FX 1180 for repair and we have no knowledge were bring them.
Hi!
Go to this link, click HERE. Then on the lower right hand side of the page there is a field for Service Center Locator where you can type in your Zip Code.
Hope this helps. Cheers!
Feb 15, 2011 | Office Equipment & Supplies
I want to reset my EPSON FX-2175 printer
load buten not worker and load buten ,paper eject not but load to load
Jun 18, 2010 | Epson FX 890 Matrix Printer
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
EPSON FX-980 RESET
don´t have reset to unlock paper motor, you need dismoun the motor to check if are damage of are the main board who make the problem, if motor are damage, de spare number are 2019040
Jun 24, 2009 | Epson FX-980 Matrix Printer
PS 2 shocked me when I was turning it off. Now it won't turn on.
When you experienced that shock you may have inadvertenly sent an electro static discharge to the circuitry inside the ps2 which would cause it to stop working.
 If it is fairly new return it to the store you purchased it let them know whar happened and usually they will exchange the item for you.
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Epson FX 1180 Matrix Printer Logo
374 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
