Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42wh36p 3 years old and it has developed line tearing or line hold drift (chassis co3p)
  • Anonymous Jan 03, 2008
    I have horizontal lines going through the tv, it gets better after 15 minutes of being switched on, what parts do i need to fix this problem?
  • Anonymous Oct 22, 2008
    I also have the same problem. The lines are horizontal and will last for up to 15 minutes, after that you get double images and eventually the picture "clears", ALMOST.
Hi..
sounds like u need a new trafo focus-t TLN2220AH.
but its rare to find.. i´ll seek for the same part and i find it in australia
Posted on Nov 07, 2008
    Genius:
  • 1,694 Answers
Please define line tearing or line hold drift==Do you mean horiz. or vertically?? Is the problem the same on all sources?? Any change hot to cold?? more diagnostic observation needed.
Posted on Sep 29, 2007
Fuzzy horizontal lines printing every 1 1/8"
Sounds like you've already diagnosed the problem.
Oct 11, 2012 | Tektronix PHASER 6180 All-In-One Laser...
32" tv, five years old
This is a typical problem with the video board inside the TV becoming faulty. I recommend taking it to the store you purchased it at and asking if they are able to fix it.
May 07, 2011 | Toshiba Televison & Video
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Horizontal lines in mits dlp wd52725 problem started right before old bulb went out, put new one in and it seems to be worse. Is picture and sound but have lines in cable, hdmi, and in aux. inputs. Is...
This has been a very common issue with this model series. Unfortunately there is no quick cheap fix. The correct way of repairing it involves removing the Chassis Cluster and sending it back to Mitsubishi for refurbishing. The cause of the problem is many capacitors are failing or have failed across 4 or 5 boards. The way the chassis is laid out it is most difficult even for the professionals
to totally tear it down and rebuild it. Average cost of refurbishing is around 600.00 to 800.00.
Because Mitsubishi is not going to support this model series much longer, I would look to replace instead of repairing it.
I hope this helps,
skyassoc
Dec 10, 2010 | Mitsubishi Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Toshiba 42" projection tv model number 42WH36P rippled effect on picture
Well this could be a serious issue you may have to call to a tech guy
good luck
Dec 18, 2009 | Toshiba 42H83 42" Rear Projection...
Kayak drifting to the left
These boats are very short and have a smooth hull with very little keel. Because of this they will not track well and will have a tendency to turn.
You don't say how experienced a paddler you are.
Check also that you are holding your paddle equi distant from both blades. You may be unconsciously paddling harder with your right hand if you are right handed. Most of us are one-side dominant. You may also be sitting slightly diagonally in the boat without realising it. Experiment with shifting your position. Also consider a backrest if one is not already fitted.
You can fit a skeg to the stern whichwill improve straight line tracking. Abit like a fixed rudder. Use heavy duty elastic to hold it onto the boat stern.
Aug 24, 2009 | Boating
ABS Sensor stuck?
No, there is not anything else holding it. Sounds like you may need to get a new sensor though. If you do, you can do anything you need to get the old one out, just don't damage the knuckle. FYI for next time, unplug the sensor from the chassis and take out with the knuckle instead of trying to remove it from the knuckle.
Aug 13, 2009 | 1998 Ford Windstar
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
262 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
