Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Cools for a limited time only before unit must be reset
The unit I bought was set up just a week ago and after my a/c guy fixed all the error messages that were coming up the unit still doesn't work properly.
The A/C will seem to be operating normally until anywhere between 4-6 hours later the unit while still sensing that it needs to cool the room only blows air at the same temp. as the room.
This is easily fixed by turning the unit on and then off again but this certainly won't work for me as I'm using the unit to cool a server room and as such is left unattended for long periods of time...
    Guru:
  • 588 Answers
If the unit was set up a week ago the technician should warranty his work and come back and take care of the problem for you, not knowing what was set up and how, it's hard to say if it's a problem with the unit or the control (t'stat or programming if it's a programmable t'stat).
Posted on Mar 17, 2009
  • 374 Answers
If this unit was new one and setting was done accurately,It sem that the ac is tripping off due to several factors in case of tripping off the compressor there is a hi pressure that building up on hi side that could not expand normally on expansion valve,there's clogging of some impurities or substance such as air in the system,this will develop a high current to your compressor exceeding to the rated current of unit,resulting to trip off the ac.You can check this on taking the operating current while the unit while is running using clamp ammeter the current will register and compared this to rated current that specified in the compressor manual or the compressor casing it was tag there.Or check again the set up sequence at the remote control the variation of thermostat setting.
Posted on Mar 13, 2009
Furnace lights blows heat in cycle, pops sensor on blower and continuosly blows air until button on sensor is pushed back in
If the sensor knocks the unit off and the the fan keeps blowing without a flame ,the limit (the sensor is a limit comptroller that turns off flame @ a set temp and allows the fan to run until the heat exchanger cools to @ set temp) has out lived its lifetime and needs to be replaced.the button is a manual reset that once reset would allow the unit to continue to run flame and blower at the same time after having been set once, if it is an ongoing problem and needs to be reset more than once then replace the limit control (sensor) in kind. (With the same mode and set-points for the limits)
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
My phone is automatically switch off
Talking on the phone with a bluetooth headset and self-rebooted.
Playing abduction and crashed. Self-reboot constantly at the X screen
Took battery out for 15 second, and tried again, same thing.
Did it a second time to fix it.
- reading google.com/reader and crashed. Self-reboot constantly at the X screen
Did a factory reset to see if it helps.
During market downloads of apps, crashed again and rebooted
Phone used edge more than 3g lately in the past few days.
After factory reset, using 3g again.
Had the phone for 3 weeks, so the tech support guy said I can only get it repaired or replaced by a refurb unit...Sounds like a bad deal to me...
and to make it even worst, I bought the google dev g1 a few months ago before this...$1k down the drain...
Feb 14, 2012 | Cell Phones
CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Mar 26, 2010 | Nikon COOLPIX L18 Digital Camera
My Garmin Nuvi 265W will not turn on. A couple of weeks ago when I booted it up, it had reset back to like new. Asking me to do set up and such. It's been cool since then. Today I shut it off at 5pm and...
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Oct 15, 2009 | Garmin Nuvi 265W GPS Receiver
SMS sending error!
if its a new phone / sim then you might need sms / wap settings sent from your service provider to set the sms message centre number in your phone etc.
Alternatively some SP's require you to call them and register a payg phone to enable full functionality, call your customer service line and explain, they will fix it right away.
Jul 29, 2008 | Samsung SGH-D900 Cellular Phone
Eject disc, power off, error message
I would just send it back, especially if it for free. I wouldnt tamper with it at all.
May 04, 2008 | Nintendo Wii Console
LG KU990 SERVICE ISSUE
That happen to me too! And they wouldn't let me get a warranty! or insurance!
I learned that its not t-mobiles fault. But thats about it.... so i brought it back to the guy i bought it from and he sent it to.. wherever it came from but they weren't able to fix it. But there getting a new hardware so there keeping it to see. Hopefully it'll get fixed.
Damn imported phones!
Mar 26, 2008 | LG KU990 Viewty
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
System error evey time I start up
If you have the warranty then return it back if not, then try wrapping it in a towel and leaving it on. It should reset itself and you will be able to play it again. It is overheating and this is a way to get it to reset itself.
Jun 21, 2007 | Microsoft Xbox 360 Console
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
133 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
