Question about HP PSC 950 All-In-One InkJet Printer
Connection of HP PSC 950 All-In-OneInkjet to Wireless N network
I would like to connect the subject printer to a wireless network which uses a D-Link DIR-615 Router. (It is currently connected by wire to a Gateway Desktop computer. Is this possible and what is required?
The computers primarily used on the network use Vista Operating Systems.
  • 240 Answers
Since your printer dont have NIC or network card..there are 2 option to connect it to your local network
Option 1
Go to Control Panel
Select Printers and Faxes
Right Click on the Printer icon
Select Sharing
then Configure it
Option 2
Buy Print server Port (Wired or Wireless)
depends on cable interface on your printer (USB or Parallel)
Posted on Mar 13, 2009
I want to setup to print wirelessly from my laptop to my hp psc 1410v all in one
This printer model does not support wireless printing. If you have connected this printer via USB cable other computer, then we could share the printer to you laptop wireless;provided the other computer is in same wireless network.
Aug 20, 2010 | HP PSC 1410v All-in-One Printer
Can HP psc 950 hook up to a network?
If this printer is wireless then you can connect it to your wireless router using the setup wizard this will give the printer driver a node name you will have to plugin your ethernet cable to set this up.
If you have other PC's that you want to use the printer add the driver as a USB driver then setup a reservation for the MAC address of the printer say 192.168.0.10.
All you need to do then is to add a standard IP port for the wired computers using this IP reservation.
For a the wireless computers you can do the same but dont use the IP_192.168.0.10 port you will need the to use the node name for example BRN12354
I have created a more detailed post with screen dumps on my tips page check it out.
Dec 12, 2009 | HP PSC 950 All-In-One InkJet Printer
I am trying to access an HP 1200 psc over a home network
Have you set up the printer to be shared via the network? You can usually set this up in printer options, through control panel. If the wifi is a closed network, so much the better. That way, nobody else can use the printer. You should be able to do this easily, as long as both computers are connected to the wireless network.
Oct 22, 2009 | HP PSC 1210v All-In-One InkJet Printer
Vista machine cannot conect thru network to printer on xp machine
Hi!
Here are all avalible drivers for that 950, vista, xp and all other OS that the printer sopports.
Download the driver you need
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=60259&lc=en&cc=us&dlc=en&submit.y=2&submit.x=10&lang=en&cc=us
Good luck
Nic
Mar 06, 2009 | HP PSC 950 All-In-One InkJet Printer
Using multiple HP printer models with same Windows XP laptop
I doubt there is a universal driver , however you could connect directly to your pc or via a router and share it over your home /business network, and access it them that way
Feb 13, 2009 | HP Office Equipment & Supplies
Is wireless operation possible
hoow do i send a fax with an hp psc 950 combination printer, fax, scanner and copier machine?
Jan 13, 2009 | HP PSC 950 All-In-One InkJet Printer
Connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Oct 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Wireless printer
HP PSC 1410 is neither a Wireless nor a Bluetooth printer.This printer will not support to any network application, but HP PSC 2410 supports.So do not confuse between 1410 and 2410.If you want this printer to be shared in the home network, then thats possible.Also if u have print server that supports USB printer we can achieve connecting this printer in the network.
Do u have any other PC that is connected to the same Home Network?
Please let me Know.
Thanks
Riz.
Apr 17, 2008 | HP PSC 1410 All-In-One InkJet Printer
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
PSC wireless scanning
Print servers do not usually allow scanning as XP and Vista.
May 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
804 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
