Question about Stoves Kitchen Ranges
YKERC607HS4 Red light indicating the front right element is on. The element is not on and when I turn the switch on the element doesn't work. Is it a problem with the switch or the element?
  • 10 Answers
SOURCE: problem with range
the sensor not working or u had a electric problem
Posted on Aug 25, 2008
SOURCE: Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Posted on Sep 12, 2008
  • 291 Answers
SOURCE: My question is in regards to my Kenmore electric
It is usually always an infinite switch, Rarely is it a surface element. The fact that the power light does not go on is also a good clue that your switch is bad. If it was a problem with the wiring to the element, your light would be on. When you order the switch, ask for the exact origional replacement. They have some generic switches that have shafts that have to be broken off to the right size for your range. These are not as reliable as the origional which usually has a much stronger shaft. Good Luck, Appliance Specialists.
Posted on Jan 26, 2010
fixyourboard
  • 310 Answers
SOURCE: Broiler will not work. Broiler Switch indicator
Three possibilities:
1. Bad Broil element.
2. Wiring problem to broil element.
3. Electronic controller failure (this can be repaired).
Posted on Feb 21, 2010
  • 447 Answers
SOURCE: Whirlpool Gold Range GJP 852400 LF dual element does not work
It is telling you that you have a problem with that element. Just like a "check engine" light in your car, it won't go off untill problem is fixed. Buy, and install a new element, easy to put in
Posted on Apr 07, 2010
No left turn signal or indicator
Hi Anonymous, start by checking for continuity at the turn signal switch, then check the wiring harness connector to your turn signal module for corroded, broken or loose pins and the red key light is your security alarm indicator light, for more information on your question please visit the websites below and good luck:
Harley Davidson Wiring Diagrams and Schematics
Harley Diagnostic Codes 04 to Present
Jul 04, 2013 | 2006 Harley Davidson FXDBI Street Bob
My right front turn signal doesn't work, I have replaced the bulb the right rear works fine
You would check the socket with a test light or meter to see if you have power and ground. If no power, the turn signal switch would be the next thing to check.
Jan 25, 2013 | 1999 Toyota Corolla
On my 2004 impala, the front right turn signal doesn't work, (only works with hazard lights). And the back right signal is fast. The signal "clicking" sound is non stop but on the other hand...
If the turn signal filament of the right front park/turn lamp is known to be OK and the hazard switch is in the normal position, the hazard switch or the turn signal/multi-function switch could be defective
Oct 16, 2012 | Cars & Trucks
Rear hazard flashers don't work 1994 Chevrolet Cavalier
Hazard flasher power comes from the 20A S/LP fuse in the fuse block. It is applied to the hazard flasher in the convenience center. Flasher output is applied to the turn/hazard/headlight SWITCH assembly where activation of the HAZARD switch causes flashing power to be applied to the turn indicators and the turn filaments of the front and rear dual park/turn lights. If replacing the fuse doesn't work, trace the power through the circuit. Check for misssing/disconnected ground wires.
Sep 16, 2012 | Chevrolet Vehicle Parts & Accessories
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Red light won't go out
If the indicator light you are referring to is the 'surface hot' light then the element has failed. Each element contains a sensor to detect when the element is hot, these sensors fail. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
If the indicator light you are referring to is the 'element on' light then the corresponding control switch has failed. Each control switch contains a switch that will illuminate a lamp to indicate a burner is on. This switch has probably stuck closed.
Jun 21, 2008 | Whirlpool RF365 Electric Kitchen Range
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
