Question about Toys
Puzzlemaker -international Dedham , MA
MISSING 2 PIECES CAN YOU HELP ME.
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Specs for Ported Box for 2 12" MA AUDIO HK12X2 Subs
Hello joseph_delac,
MA Audio's website has the recommended box volume and port size online here. A ported enclosure needs 3.0 CuFt of internal volume and the port should be 48 sq/in and 14.5" in length. A 4X12" rectangular port would give you the recommended 48 sq/in. Using 3/4" MDF, a box 16X18X25 has an internal volume of 3.25 CuFt allowing .25 CuFt for the sub and port displacement.
Hope this helps.
May 13, 2009 | MA Audio HK12X2 Car Subwoofer
C4180 Won't Power On
Make sure the plug is all the way into the AC adapter. Then, you will need someone to verify the output of the AC adapter. You should have a 16VDC and a 32VDC output from the adapter. If that is good, you have an internal problem with the printer. If the output voltage(s) are missing you will need to replace the AC adapter.
Here are the specs:
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
  • HP part# 0957-2146 Call 1-800-227-8164 for availability.
  • Nov 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Rear view projection t.v
    Hello riff5000719,
    The problem with your TV might be the convergence correction amplifier modules (2 STK392-110). These modules often malfunction and produce the symptoms you are describing. The cost of the parts is about from $12.00 - $32.00 depending where you buy the parts from. The major cost will be the labor, and if needed the cost of installing the biasing circuitry that the modules use. This usually costs around $200.00 - $400.00 depending on the shop.
    Getting rid of it might not be warranted if you can spend the 200-400 to get it repaired.
    I hope this helps,
    Thank you,
    Shuttle83
    Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
    No detection
    unhook ext drive from laptop...turn off hd...then reconnect to laptop..then turn hd back on..see if you can see it then.
    check your computers warranty here 4 FREE
    Mar 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Toys Logo
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Toy Expert? Answer questions, earn points and help others
