Question about Crosley CAWC529JQ Top Load Washer
Crosley washer cawc529pq0
The on/off power switch has stopped working--no power, the plastic cover over the electronic control panel cracked and broke in pieces over the on off switch section of the control panel. I don't know if it needs the bubble of air or if the problem is actually the control panel. I only want to replace what is necessary. How can I determine if I need the control panel or just a new cover?
3 Suggested Answers
SOURCE: Timer knob on washer broke off leaving the plastic sleeve attache
I did fix this problem myself, I found a heavy duty 'bread tie' type of wire, I tied it around the base of the stuck sleeve and wrapped the loose end of the 'bread tie' around my pliers and pulled very hard and it shot off like a bullet, I am now using my replacement knob..yeah for me..
Posted on Jun 13, 2009
richroth
  • 9472 Answers
SOURCE: Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Posted on Apr 27, 2012
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 29, 2013 | Crosley Dryers
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a toastmaster t80bc and the clear plastic part that locks down the handle on the inside popped off, anyone have a pic or diagram of how it goes back on. Nothing is broke it just came off and its...
yes I got the same problem, I Fix myself.(model T80BC)
unplug main power cable, remove top cover (remove 4 screw from the bottom and knob from the side)disconnect control panel cable from main board.look at the attached picture.in the photo close to power cable connector will see a slot
(look at the black arrow mark pointed ).insert plastic switch to this slot, make sure both side properly mounted.then move toaster push down lever up and down. it should move as usual without any obstruction. now put back control panel cable and top cover,knob,and all the screws. plug cable into the power,it should work.
see switch
Feb 26, 2010 | Toastmaster Kitchen Appliances - Others
My crosley washer filled with water and stopped working. the water level light is blinking, but it won't finish the cycle. can you tell me what the problem is?
there may be a problem with the pressure switch.there may also be a problem witht the lid switch.try and unplug the unit and see what happens.
the main control board would be the last thing to go out and need replaceing
Jan 31, 2010 | Crosley CCW5294W Top Load Washer
My washer will not stop filling and overflows the tub.
Good day,
If shutting off the power to the machine stops the water flow, then the water valve is O.K.
Three possibilities.
1. The pressure switch in the control panel has failed. or....
2. The plastic hose going to the pressure switch has come off ..or
3. It is plugged up where it is connected to the bottom of the rear of the tube and must be blown out.
You can access the pressure switch and hose by removing the 2 screws at each corner of the counsel ( may be hidden by plastic covers that have to be unclipped) and then lift slightly forward and then flipped completely up and over.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
My Frigidaire Gallery Front Loader Won't Spin...
The motor have froxze up. First make sure the belt has not broke. Remove the rear cover and you will be able to access the motor and belt.
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Power Switch - Washer
I feel your pain, Amy. I've worked on this appliance and have experienced all the error codes and load balance problems, you've explained. There are many of you that wish they had not spent the extra money on this set.
Your problem is more than likely the User Interface Control board located under the console. Unfortunately, the power switch is not a separate part of the board. The board is sold as one assembly and what typically happens is one or more of the small buttons wear out (usually the ones used more frequently). Replacing the board is simple if you wish to pursue a repair on your own and avoid unnecessary labor charges.
You can go to searspartsdirect.com and type in your COMPLETE model number. There are several variations of your washer listed, so make sure you type in the model number correctly. The part you need can be found under the "Control Panel Parts" heading as item number 7 (part #8564290). The card is not cheap. It runs around $113.
To replace the board follow these simple steps:
1. UNPLUG washer.
2. Loosen the three screws in the back of the control panel.
3. The control panel will lift from the back first, then off. Be careful not to damage the small interface cable that connects the control panel to the main control board.
4. Disconnect the interface connector and remove the control knob on the front of the panel by pulling straight out.
5. Place the control panel face down on a padded surface (like a stack of towels) and remove the series of screws that hold the Interface Control Board in place.
6. Carefully remove the plastic cover from the circuit board. It is held in place by a series of tabs.
7. Install new circuit board, using care NOT to handle the surface of the board with your hands. Handle the sides of the circuit to minimize the possibily of damage caused by static.
8. Install rear cover and reconnect the interface cable.
9. Re-install control panel by inserting the front section in the grooves on top of the washer first, then lower towards the back.
10. Tighten all screws and re-install control knob.
It's not a difficult repair at all. If you do not wish to order parts on line, you can use the part number provided and go to your nearest applaince parts retailer to see if it may be available. I hope this helps. Please post back if you have any questions, or require further assistance.
Jun 06, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
