Question about Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray
Which key to press at startup to gain access to BIOS E2180 Intel
Cant locate manual and have forgotten how to get to BIOS. Need to change option so Intel Pentium E2180 will boot from CD. Have tried F2 and F5 at switch on but not successful. The answer must be SO simple !
  • Vincent  dela cruz
    Vincent dela cruz May 11, 2010
    what mother board are you using?
    most Clone mother board use this key:
    Del
    Ctrl+Del
    Ctrl+F10
  • 8 Answers
At initial startup, entering BIOS setup should be the DEL key (delete key).
but you can also hit F12 to bring up a "boot menu" if your computer supports it. this will allow you to boot from another device without having to go into bios setup
Posted on Mar 13, 2009
    Scholar:
  • 54 Answers
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Add boot option and change boot to usb
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. In boot options make USB 1st. Save and reboot.
Note: Some systems have an boot option during startup. Thus eliminating the need for BIOS change. Again, look on the screen for F key.
Oct 28, 2012 | ASUS U46ERAL5 Notebook
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer.
Dec 21, 2010 | Gateway M465-E Notebook
I forgot my HP window 7 password and don't have a back up disk what do I do??
HI there,
Working from a computer that will burn a CD, you need to download "Hiren's Boot CD" for the link below and burn it to a CD. When you power on your computer with the forgotten password, insert the CD and restart. To access the Boot Device Options window, turn on the computer and immediately press the esc key to display the Startup Menu, and then press the F9 key. Then choose to boot from the cd/dvd drive.
Hiren's is a free tool CD and is awesome. It will break in and let you change your windows, BIOS, HDD pasword and do about 100+ other amazing things.
http://www.hirensbootcd.net/download.html
Now you save all your friends' *A--es* too.
Enjoy,
Marcus
Sep 21, 2010 | Computers & Internet
My gateway 2118u netbook will not boot or turn off the screen says: For Atheros PCIE Ethernet Controller v2.0.0.9(05/08/09) Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable...
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Sep 09, 2010 | Gateway LT2001u Netbook
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Can't access BIOS
Eject and re-insert the bios battery.
Aug 30, 2009 | Intel Motherboard
BIOS setting changed
pressing f8 or the DEL key or maybe even f6 will take you back to the bios on startup
you should see a quick message telling you which key to press on startup
Jun 29, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray  Logo
626 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
