Help me please
The heater blows only cold air? No heat! It is a 7900-6021 model a guy came over to fix it and messed up wires! Know both are like a/c
    Problem Solver:
  • 8 Answers
The problem you have is likely not going to be solved this way. First you don't give us enough info on what type of system u have and second without a wiring schematic it is nearly impossible to fix without being there. Even being there it would take some time to figure out where the wiring is wrong. A more detailed description may help.
Posted on Apr 30, 2013
  • 18 Answers
SOURCE: Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Posted on Dec 23, 2007
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
diths_kri
  • 67 Answers
SOURCE: My Heater blows cold air
IGNITE PROBLEM
Posted on Jan 07, 2009
  • 13 Answers
SOURCE: No heat, just cold air blowing
the problem you are having is usualy related to. #1 a high limit condition.(check the filter,then cycle the power off then on). Does the furnace have a diagnostic indicator?
Posted on Jan 11, 2009
No heat blowing cold air
Heater blowing cold air? - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan.../233563-heater-blowing-cold-air.html
Nov 5, 2006 - 15 posts - ‎6 authors
... it idle, all guages normal, heater on HOT and HIGH, it blows cool air. .... thatNissan put out for some reason (I have no idea where it went to, ...
How To Fix Your Car's Heater - YouTube
? 3:03
https://www.youtube.com/watch?v=bmmn4ON_t0c
Nov 26, 2009 - Uploaded by Scotty Kilmer
... Scotty Kilmer shows how to fix your car's heater for those coldwinter ... How to Diagnose and Fix No Heat Issues - Also a Demonstration on ...
maxima blowing cold air while idling - Maxima Forums
maxima.org/...maxima.../599527-maxima-blowing-cold-air-while-idling....
Sep 21, 2009 - hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving. ...Not sure whats involved in a heater core for the Max, but I had to pull the ...
Jan 15, 2016 | Halonet 95-99 NISSAN MAXIMA / 96-99...
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Dec 16, 2015 | Cars & Trucks
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
My 04 dodge stratus heater/defrost doesn't work very good. You can take the dash control unit out and mess with the wires on the back of it and it will blow hot air for a little while. I use to do this...
Sounds like the control unit or wiring (since you could mess with the wiring to get it working). The controls aren't controlling the dampers in the ductwork to control hot/cold, etc.
May 19, 2017 | 2004 Dodge Stratus
Chevy astro van heater blowes only cold air
the problem is probably the heater core, it can become clogged with dribris. this stops heat from the engine getting to it and then no heat.
Dec 08, 2009 | Chevrolet Astro Cars & Trucks
When on AC the air blows hot, when on heat the air blows room temprature
This is a wiring issue or you have a heat pump and the reversing valve is stuck.
Jun 03, 2009 | Honeywell Electronic Programmable...
Heater blows cold air when it is 30 degrees out side
heat pumps don't work as effient at that temp thats why they have 2nd stage supplemtial heat
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
