How do I disassemble a kodak esp 3.2 all in one printer
Paper input catch does not catch properly
  • 20 Answers
SOURCE: kodak esp 3 printer not printing properly.
you need to clean the printhead
Calibrate the printer (Scan + Cancel)At the same time for 5 seconds
Do a demo page ( Scan + Copy )
And go to the website :
www.kodak.com/go/esp3downloads
And download the latest version of the firmware
your all set after
Visit also the website
www.kodak.com/go/itg
for the troubeshooting guide
Posted on Mar 25, 2009
  • 20 Answers
SOURCE: Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Posted on Apr 01, 2009
  • 6 Answers
SOURCE: Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
Posted on Apr 18, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
SOURCE: Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
Kodak all in one printer taking in paper crooked and jamming every time!
look for a piece of paper blocking the path.
or a feed roller that's crooked.
something is catching the paper and making it go crooked.
Mar 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Need to replace broken paper tray. Does parts manual show how to order.
You can buy them on ebay like the following link. Kodak does not sell the part on its own. Printer is to cheap for that.
http://cgi.ebay.com/Kodak-ESP-3-ESP-5-Paper-Tray-/200578575161
Mar 07, 2011 | Kodak ESP 5 Printer
How do I get a piece of paper that is jammed out of my Kodak Kodak ESP 3 Multifunction Printer/ Copier/ Scanner?
you need to open this printer remove the toner cartridge, this will enable you reach the paper stocked in the printer.
your vote counts
Mar 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Several pieces of paper fed in printer and now I have a paper jam and cannot remove the paper
...look at the printer manual to remove jams. Some time you may have to remove the difuser to get rid of them. Depending what type of printer you have. Remember you can go on line to download the manual if you don't have one available. Check if the paper is catching excesive mousture and that the roller that catch the paper have been given proper maintenance. Tks.
Jan 14, 2010 | Kodak ESP 5 Printer
Kodak ESP 3 printers are a ROYAL PAIN!!!
If your replacement is the same as you had, then you need to go to control panel and delete the driver. Afterwords when you plug in your new one it will install the proper drivers for the new machine. Even though it's the same type your computer won't use it properly til you re-install.
Aug 11, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3:paper light flashes red,can't print-is totally useless
kodak has certain problems with esp-3 printers. it cannot give u a cash refund call kodak @ 1800 421 6699 . they will upgrade ur printer and give u a kodak esp-5. they have been giving esp-5 lately in return for esp-3
Jul 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jammed in my new kodak esp 3 printer no idea why this happened. i put the paper in the right way...can anyone help
Try to clean the rubbers that pull the paper from the tray.
Use quality paper, and pay attention to the place where you store it. Keep it in a dry place.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
MY ESP 5 PRINTER WILL NOT DETECT THE PAPERS EDGE.
Kodak printers support the following paper sizes: 3½ × 5 in. 4 × 6 in. 4 × 8 in. 4 × 12 in. 5 × 7 in. 6 × 9 in. 8 × 10 in. A4
Make sure that the grey coloured paper alignment is aligned properly to the edge of the paper.
turn your printer off and then turn it on again. put papers and align the paper alignment. try to print,your issue will be resolved.
Apr 04, 2009 | Kodak ESP 5 Printer
460 people viewed this question
jasbo
jasbo
