Question about Amana ARS266ZBS Side by Side Refrigerator
Freezer working fast freeze
I have a jarp freezer and i want to turn off fast freeze button but i diont know which button is fast freeze off.i have a blue zigzag lighying bolt button and a amber snowflake button.and dont know which is which
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Freezer has a rocker switch which side should it normally be on s or o? I KNOW IT IS TO DO WITH FAST FREEZING.
When it's running to temperature, switch the switch. If the compressor turns off that's the normal position. If the compressor just runs and runs it's in fast freeze
Dec 13, 2015 | Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Can only get freezer to work when quick freeze is turned on
Your thermostat is faulty. Run it in fast freeze mode until you can get it replaced
May 04, 2012 | Freezers
I hav 2 buttons that hav signs on it at the top of my freezer i dont know what theyre for...if i push 1 of the buttons it lights up so i dont know if they should be on or off cause i dont know what theyr...
An orange button with a snowflake on it normally means 'fast freeze' and should only be used (lit up) if you have added a large item to the freezer and want it to freeze quickly. I assume the button marked 'super' means 'super fast freeze' but without knowing the make and model of your freezer it's difficult to be certain. If you can provide those details I will respond again.
Jan 04, 2011 | Microwave Ovens
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Amana ARS266ZBS Side by Side Refrigerator Logo
43 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
