Question about Ergogenesis BodyBilt 2507 High Back Executive Chair
Replacement Parts Where can I find Armrest length adjustment screw, I misplaced one of it while moving ?
Where is the power armrest control located?
It should be in the vicinity of the armrest....Is this a door armrest or center console armrest? In either case, the adjustment will be near to the armrest, like the seats have an adjustment at the hinge area.
Mar 31, 2016 | 2000 Isuzu Trooper
When making buttonholes, the machine will not zig zag in reverse when doing the right side of the buttonhole.
1. Remove the top.
2. Clean the inside with carburetor cleaner and lubricate with sewing machine oil.
3. While After this move the stitch length back and forth from a long arm to the reverse mode. Rotate the hand wheel several times to lubricate all moving parts.
4. Place some rags under the pressure foot and watch if the rags will back up.
5. Remove the bottom of the machine.
6. Clean the bottom moving parts and lubricate.
7. Rotate the hand wheel and watch the feed dogs to see if everything is moving.
8. It is possible to notice a screw attached to the stitch length adjuster that will have to be tightened. This may require you to move other parts that are attached and apply pressure while doing this.
Apr 02, 2015 | Sewing Machines
Fabric not feeding on singer model 750
check that the feed button or lever is in the correct position
If it is in the centre position then the feeding foot doesn't know to go forward (normal ) or reverse
If electronic controlled the maybe a service is called for.
Mar 29, 2015 | Singer Sewing Machines
Trying to find the right handed arm rest for Ever med wheelchair, model CBS 89, Serial number: 20013940. Where can I get this part?
depending on the type of arm rest you might have a look on eBay for " wheelchair arm rest" there are several universal types, they are often far cheaper to buy a new pair that to just replace one with original genuine parts.
Dec 16, 2014 | Health & Beauty
Which of the 2 screws on the front deraillier gear do i adjust to move the gear slightly outward ie 1 click out on the gearstick
hi.
you would not normally adjust these screws as they are to stop the gear moving too far in or out. to move the gear slightly out to line up with the selector position, you would normally alter the cable length by turning the adjuster on the and of the cable where it goes in to the deraillier itself.
hope this helps.
Aug 18, 2011 | Cycling
2 items. Front basket support and armrest
You shold be able to order replacement parts for both the basket and the arm rest. Have your serial number ready. You can contact me if you would like them ordered.
John R.
May 30, 2010 | Pride Legend 3 Wheel Mid-Size Scooter
How to remove door panel on a 1985 cadillac eldorado
Very easy! One tool that will save you a lot of headache and anger can be bought at any auto parts store and looks like this:
You use this tool to pop loose the plastic fastners that are attached to the door panel edges.
But first, remove all screws...remove the door handle cup, pop loose the master door/window stich assmbly, etc. Very simple process....takes less than 10 minutes.
Door Panel
  1. Remove all door inside handles.
  2. Remove the door inside locking rod knob.
  3. On styles with door pull handles, remove the screws inserted through the handle into the door panel.
  4. On styles with remote control mirror assemblies, remove the remote mirror escutcheon and disengage the end of the mirror control cable from the escutcheon.
  5. On styles equipped with switch cover plate in the door armrest, remove the screws securing the cover plate, then disconnect the switches and cigar lighter, if so equipped, from the harness connectors.
  6. Remove the remote control cover plates and remove the exposed screws securing the cover plate to the door inner panel.
  7. On styles with integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. On some styles it may be necessary to remove the screws behind the armrest deflector or courtesy lamp remote control cover plate. On styles with armrest applied after the door trim installation, remove the armrest to door inner panel attaching screws.
  8. On styles with with two piece trim panels, disengage the retainer clips at the front and rear of the upper trim panel. Remove the upper trim panel by lifting upward and sliding slightly rearward to disengage the the front door inner panel at the beltline.
  9. On styles with electric switches located in the door trim panel, disconnect the wire harness at the switch assembly.
  10. To remove the lower trim panel, remove the attaching screws along the upper edge of the lower trim panel. Then starting at a lower corner, insert a pry type tool between the door inner panel and the trim panel and disengage the retaining clips down both sides and across the bottom. On styles with courtesy lamps or reading lamps located in the trim panel, disconnect the wire harness at the lamp assembly.
  11. On styles with one piece trim panels, remove all the clips around the perimeter of the trim panel. Push the trim panel downward and outboard to disengage it from the door inner panel at the beltline. Disconnect any courtesy lamp wire harnesses, if so equipped and remove the trim panel from the door.
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation
May 08, 2010 | 1985 Cadillac Eldorado
The arm rest does not move to a parallel position
Un zip the cover on the armrest and pull it up to expose the bolt hole. unbolt and remove the arm rest and see what parts are damaged, sometimes it can just be tightened.
Feb 12, 2010 | 1990 Ford Bronco
Left power mirror replacement
There is a Technical Service Bulletin on the power mirror actuator for replacement. If your mirror just stopped operating, I would take it back to the dealer and they will fix at no charge due to the TSB.
For removing the door panel
  1. Remove window crank handle or power window switch assembly (if equipped).
    • Disconnect harness connectors.
  1. Remove pull handle escutcheon.
  2. Remove pull handle cover and remove screw.
  3. Lift armrest upward to release clips and remove armrest.
    • Remove front door finisher screws behind armrest.
  1. Release clips and remove front door finisher.
    • Disconnect lock cable and handle cable from inside door handle assembly.
Feb 11, 2009 | 2007 Nissan Xterra Off Road
Ergogenesis BodyBilt 2507 High Back Executive Chair Logo
69 people viewed this question
Top Ergogenesis Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Ergogenesis Furniture Expert? Answer questions, earn points and help others
