Question about TruTech PLV1615T 15 in. LCD Television
Intermittently shuts off
I have a Trutech PV1615T LCD 15" SD/HDTV that shuts off for no apparent reason. Does anyone have a repair manual so I can replace the on/off switch?
Also, trying to find the code for Dish Network to use their remote.
Thanks
  • info621 Mar 14, 2009
    Thanks, I have had several people in the industry say its a common failure with the set. They believe the intermittent shutting off is likely the switch shorting out. Its a varied pain...one minute its on, the next its off, three hours its on, the next minute off. Its random and never consistent. The only way to get it to turn back on it to unplug it then plug it back in and turn it on.
    Sergeant:
    Champion:
  • 431 Answers
To determine if a tact swtch is bad put the meter on it ohms will be open circut hit switch will be short 0 ohms you usually can feel if it is bad by contacts but if it turns your tv on and off it is good shutting on and off randomley will be on your logic pcb
Posted on Oct 12, 2010
    President:
  • TruTech Master
  • 1,779 Answers
I know of no manual available for Trutech except maybe a flow chart. If you believe the tac switch is bad, all you have to do is un-solder it and use the remote to turn it on and see if it quits. You will probably have to locate a tv shop in your area that may have a scrap LCD set that he can match and take the tac switch out of. I have not encountered a bad tac switch by normal failure yet, in an LCD set, so I'm wondering how you determined the switch is bad? Please let me know?
Posted on Mar 13, 2009
Will Mohu Leaf HDTV antenna work with TruTech PLV1615T?
It may simply be if only one local channel the signal is not strong enough for the set to pick up.
Mar 31, 2012 | TruTech PLV1615T 15 in. LCD Television
PVS21175a1 TruTech 17" LCD TV
call mfg ask them where to buy they have repair depos thet carry the supply in your area
Aug 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Tv shuts off for no apparent reason
one of your circuits is getting too hot maybe the flyback is going bad,,,one of the two is wrong
Dec 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Keeps turning off
i'd check the power supply or the fan. the tv will shut itself off if it gets too hot or doesn't register the fan as working, not to mention need full juice to run....
Nov 20, 2008 | TruTech PLV1615T 15 in. LCD Television
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
Remote code so TiVo clicker can operate TV
Try LG, Goldstar, or Vizio codes. Otherwise, visit the product website. If you have a Trutech LCD TV, you can check at http://www.1800customersupport.com/trutech
Jul 22, 2007 | TruTech PLV1615T 15 in. LCD Television
TruTech PLV1615T 15 in. LCD Television Logo
172 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
