Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I have a dlink router and I want to connect my usb modem to it
- I want to be able to connect to the internet with my laptop and desktop pc
- the model of the router is D-Link WBR-1310
- the model of the modem is Westell 6100
- the computer I have won't work with the ethernet ports, so I have to use the usb port.
- my isp is verizon high speed
  • 240 Answers
Is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
I have a dlink router and I want to connect my usb - bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possI have a dlink router and I want to connect my usb - bred.gifetwork that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configurationI have a dlink router and I want to connect my usb - bred.gifs. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restI have a dlink router and I want to connect my usb - bred.gif computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
Step 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NICI have a dlink router and I want to connect my usb - bred.gifn power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged EtI have a dlink router and I want to connect my usb - bred.gif/b> from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the I have a dlink router and I want to connect my usb - bred.gifare saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
I have a dlink router and I want to connect my usb - image92920.gif://i.fixya.net/uploads/images/bred.I have a dlink router and I want to connect my usb - image92921.gif.gif" class="h_mi" />Step 4
bred.gifStep 5
UseI have a dlink router and I want to connect my usb - image78985.gif steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouthI have a dlink router and I want to connect my usb - bred.gifter your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Posted on Mar 13, 2009
    Scholar:
  • 26 Answers
Hi cubase,
You will need a USB-ethernet adaptor which can be purchased at most computer stores in order to connect to your router which in turn is connected to your modem.
Hope this is what you were looking for and please take the time to vote!
Dlink dir-142 Dodo usb prepaid dongle t12146l140 no connectivity optus usb prepaid dongle e169 responsive, no internet coverage connects with nintendo 3ds but no internet connection. windows xp...
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
Jun 14, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
I have configured my DLink dual band router as well as my usb adapter. On my connection manager it says it is at 100 %, but my internet access is not avaialable. I have a yellow house and am not able to...
IF it says you are connected wireless, you are connected the DLink router. But the DLink router is not configured properly. If you connect your pc directly to the modem and goes online then that is a proof that the DLink is not properly setup. There is a possible IP conflict between the modem and router. I suggest you change the IP address of the router to 10.10.10.1 .
Apr 05, 2011 | Computers & Internet
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
Desktop works fine connected to cable modem but when hooked to dlink the internet connectivity
If you connect the desktop to the modem it works that means modem is working.
Now connect the modem to the router and computer to the router.
Open the set up page of the router. and change the settings of the router according to your internet service provider.
Click Here for step by step instructions
Dec 05, 2009 | D-Link DIR-825 Wireless QuadBand Router
When trying to wireless connect my laptop through my desktop pc connection fails. Have tried reconfiguration of both the 'DLINK' modem and the Laptop without success.
Try resetting your desktop back top a static configuration. ie: Do not assign a ip.
You system will assign a ip of 192.168.0.1 most likely.
Now, disconnect your modem from its power source and remove its battery for 30 seconds.
Next, disconnect your power source to the router or hub.
Now, go ahead and hook up your power connections to the router and install your battery and power connection to your modem.
Allow your modem to fully setup before attempting to go further.
Now, reboot your desktop and try your normal internet connection..
If it works ok, leave it and go to your laptop.
Leaving the desktop unit on, startup your laptop.
Your laptop should see the static address from the desktop and assign itself a different number, one that does not conflict with the ip address of the desktop.
Hope this works out well for you.
John
Nov 27, 2009 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
1,659 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
