Sanyo model ce37ld81-b
Will not switch on blue light stays on
    Top Expert:
  • Televison & ... Master
  • 36,311 Answers
Probable power supply trouble
Posted on Apr 24, 2013
Ce32ld33 tv sanyo turns on stays on for couple hours then turns off and stays off until an hour or 2 then switches on .i try to switch it on after about 20 mins but the little blue standby light goes...
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
Oct 04, 2011 | Sanyo Televison & Video
We have 42" Sanyo tv
Check first the menu setting.If the setting is in VIdeo or in Tuner.
Sep 04, 2011 | Sanyo Televison & Video
When I turn on my new Sanyo VPC S1285 camera it stays on the blue "Sanyo" screen
When I turn my sanyo vpc-s1285 on it stays of the blue Sanyo Screen Can you help me fix this?
Apr 04, 2010 | Sanyo Cameras
Sanyo tv when switch on has a blue box with
my sanyo tele isnt switching on, there is a white light flashing, but nothing is switching on?
Jan 02, 2010 | Sanyo Televison & Video
Screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Aug 22, 2009 | Sanyo Televison & Video
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
