Question about HEWLETT PACKARD - LASER JETS HP LaserJet Enterprise 600 M601n Printer
Cold reset - HEWLETT PACKARD - LASER JETS HP LaserJet Enterprise 600 M601n Printer
    Problem Solver:
  • 17 Answers
Try this : http://h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/202232/1/output.pdf
Posted on Feb 02, 2015
How do i cold reset
Cold reset
A cold reset unlocks menus that have been previously locked and resets all control panel menu items to the factory defaults. A cold reset does not clear the values in the service menu, such as the serial number and the page counts.
NOTE: Before performing a cold reset, print a menu map and a configuration page. Use the information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before performing a cold reset. Make note of the IP address that is listed on the Jetdirect configuration page. You will need to restore the IP address after performing a cold reset.
To perform a cold reset
1. Turn the MFP off and then on.
2. When the memory count appears on the control panel display, press and hold 6 until all three LEDs flash once and then stay on. This might take up to 20 seconds. wait until the machine display gives you the next option this may take upto 2 mins again
3. Press 3 four times until COLD RESET appears on the control panel display.
4. Press 6 one time. The MFP continues its initialization sequence.
a cold reset has been performed.
Jan 24, 2014 | HP LaserJet 4730 MFP Printer
51.20 error
Hi Do the following and good luck. You may have to sen away for parts.
So, please perform the following steps to isolate the issue to its exact cause:
1. Power is an important part of LaserJet printing and inadequate or marginal power supply can cause this sort of issue to occur. Please plug the printer directly into a wall outlet to eliminate the possibility of power issues caused by other power devices.
2. Then, remove the black cartridge and clean the E-label as well as the metallic toner contacts at the cartridge ends using a dry linen cloth. Then reinsert the cartridge.
3. Then, please perform a cold reset on the printer. A cold reset clears all data from the printer memory and sets all the defaults back to the factory settings.
CAUTION: Performing a cold reset resets the Jetdirect configuration. To avoid making changes to the network configuration, remove the HP Jetdirect print server before performing a cold reset.
NOTE: If possible, print a configuration page and menu map prior to performing a cold reset. This will document the current settings for later reference.
Perform a cold reset from the printer as follows:
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
d. Release the (Select) button.
e. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button until control panel displays COLD RESET.
g. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Jun 16, 2011 | HP LaserJet 3600n Printer
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
How to fix cold rest on HP lazerjet 5100
Cold reset CAUTION: A cold reset will reset the HP Jetdirectcard, even if removed. Print the Configuration page before performing a cold reset. The customer must have the ability to reconfigure the HP Jetdirect card and be willing to accept this responsibility.
  1. Turn printer off.
  2. Hold the ONLINE key down.
  3. Turn printer on.
  4. Continue to hold the GO key until the printer reads Cold Reset .
  5. Release ONLINE.
    • Initializing appears.
    • Then, Restoring Factory Settings.
    • Followed by Offline.
  6. Press the ONLINE key to put back online.
    hope it helps, if so do rate the solution
Nov 29, 2010 | HP LaserJet 5100 Printer
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
3. While the product is performing its memory count, hold down the #6 key. When the three status
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
Cold Start
Hi patricia_kin:
Hope this helps.
Cold reset
A cold reset unlocks menus that have been previously locked and resets all control-panel menu
NOTE Before performing a cold reset, print a menu map and a configuration page. See
Information pages. Use the information on these pages to reset customer-specific settings.
configuration page. You will need to restore the IP address after performing a cold reset. See
Configuring and verifying an IP address.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Jul 22, 2009 | HP LaserJet 4345mfp Printer
Change my printer network access password
For an HP Officejet printer:
You can reset the printer definitions taking off the power cord and holding # + 6 buttons (semicomplete reset) or # + 9 (full reset) while connecting power cord again.
For an HP Laserjet printer:
Try logging in with admin as username and leave the password blank.
If not, preform a "cold reset" on the printer which resets parameters back to factory defaults. You want to print off a configuration page first. From the service manual :-
Cold Reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Apr 09, 2009 | HP Office Equipment & Supplies
Laser printer keeps printing hp ads
Please perform the following:
If the printer is connected via network, unplug the network cable and perform cold reset.
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
Then uninstall / delete the previous drivers and install the drivers from the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845555&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-45284-8
Sep 11, 2008 | HP LaserJet P2015dn Printer
HP 2015 clear password
I would try the cold reset again. From the service manual :-
Cold reset
Sep 10, 2008 | Office Equipment & Supplies
HEWLETT PACKARD - LASER JETS HP LaserJet Enterprise 600 M601n Printer Logo
219 people viewed this question
Top HEWLETT PACKARD - LASER JETS Office Equipment & Supplies Experts
David Payne
David Payne
Graciano Leitao
Are you a HEWLETT PACKARD - LASER JETS Office Equipment and Supply Expert? Answer questions, earn points and help others
