Question about Tomtom RIDER GPS Devices
Tom To Rider
I have the following ongoing problems as listed below 1. Bike charger not charging - was connected by an auto electrician to the ignition on/ off wire but no joy. 2. It turns off during journeys , several times in a single journey.-Itsometimes comes back on its own , other times I have to pressand hold the on button on the right hand side of the Rider. 3. Its happened four times that it just wont turn on at all after being switched off even though the battery still has charge on it . Fortunately when eventually getting hold of a thin needle I am able to reset it and it starts working again . Please advise as Its frustrating that I ve spent £500 for an unreliable , untrustworthy product. I know That You didnt design these units but its sad that they dont quite do what it says on the box, cosistently enough. Ive spoken to severa other users on the net and many experience similar problems so I ve been nominated to try and source some solutions to these , please assist me wherever possible with this venture. Thanking You in dvance Victor 0777 867 6625
  • 4 more comments
  • Vitor Ferreira Aug 05, 2007
    Thank You for the prompt response , I will definitely do that solder bit .You are a true legend , thank You.
  • Vitor Ferreira Oct 04, 2007
    ts a sad issue isnt it mine keeps giving me hastleds too.Its a vibration issue
    The question is what is TOM TOM doing about it?
  • fat-mal May 10, 2008
    rider charges on mains charger and on in car charger but not on bike mount. I have checked supply to the bike mount and there is 12 volts at the plug in the base of the mount. help..............malcolm
  • Anonymous Jul 05, 2008
    Rider not charging from the bike cradle. I have checked the cradle and there is 5 volts present at the pins, but it does not charge the unit.
  • divecapt Jul 18, 2008
    I tried the solder solution over a year ago. As stated, it works for a while. The longest lasting fix I have found is a small bungie cord streached tightly around the unit and bracket. This has worked for over a year, but now I have another problem. The battery is dying and Tom Tom service tels me it is non replaceable. I ordered what I thought was a replacement battery, but it was the wrong size and shape. Once I found the special bits to remove the back, I found that the battery in my V1 rider is large and round where the replacement was a small rectangle. Customer support at TomTom is a joke. They have never resolved an issue that I reported. Don't waste yout time. Buy a Garmin.
  • bagbag Jul 21, 2008
    Plug-in to power supply on BMW bikes and it stops working after about 10 hours use and won't work again. Has to be a problem with plug-in TomTom mounting unit since I can get it to work with plug in to car. Tests on both bikes show power supply hot. Have had 2 uints do this. If no help from factory soon, would not recommend this unit to anyone.
Yeh, im currently travelling round corsica and the pins are a joke;;;;;its on my single ktm -'à and the vibrations have made holes in the ' contacts in the back of the tom tom;;;;;it has also shortened the contacts on the holder through vibrations.....this is even after the plastic broke off after (50km of rough roads....) now need to locate somone in France who can a) speak english and b) solder!!!!!
Posted on Aug 05, 2008
Unfortunately I have encountered the same issue with my Tom Tom Rider. I have worked out the problem is between the mounting bracket and the GPS unit. There are 4 little metal pins that spring in and out on the mounting braket that are supposed to be in touch with 4 metal cylindrical metal surfaces on the rear of the GPS head unit. This looks good in design and theory, but the GPS unit does not always make contact with the metal pins, hence allowing no charge to GPS unit and automatically turns itself off whilst riding. I have sort to overcome the issue with building the rear of GPS head unit cylindrical contact points with solder. It is a fiddly fix, but to date this has overcome the issues you have named up. A small drop of self fluxing solder is all that is required. No more than 2mm projection off GPS unit. Allow the solder to adhere to contact and move soldering iron towards the base of GPS unit. The reason for doing this is to allow the pins extra contact surface. I found my pins on the mounting unit did not line up with GPS head unit when fitting together from new. It's not easy to see this, but shine a torch light as you bring 2 surfaces together and you will see what I mean. The mounting braket pins were slightly lower than the GPS contacts. This is what causes the problem. Hopefully Tom Tom will redsign these on the next model or allow more contact space and tolerances to eliminate this frustration. Regards, Nicky (fellow Tom Tom Rider)
Posted on Aug 05, 2007
  • Nicky Gray Aug 30, 2007
    I need to add the above solder fix is not a sure fix. I have since had issues with my Tom Tom still cutting in and out whilst in the cradle. The vradle mount doesn't appear strong enough to support the GPS unit and any bike viabration causes the contacts to cease touching causing the GPS unit to turn off and reset itself. This can be very frustrating if you are relying on GPS to navigate you in a certain place. Initally the solder assisted to keep the electrical contacts in place.
    So I have decided to take the issue back to Tom Tom as I have read many disgruntled comments regarding this same issue on the web and I believe Tom Tom need to rectify the problem for their own future sales image. The GPS unit is fine and easy enough to operate, but feel free to try what I suggested above using solder, but I'm afraid it is not the answer...
    Regards,
This is one possible solution ww.fon.gs/ttrider
Posted on Sep 06, 2007
Problem with my tomtom go 910, was working perfectly until i went on vacation for five weeks. Went to use it and could not switch it on so i thought the battery must be low, so i was going out in the car...
1. Connect the GO to your home charger and charge it for at least two hours. You need to charge your ONE or GO300 for at least 2 hours using the 12-24V cigarette lighter adapter in your car.
2. Check if the green light on your GO lights up when connected to power (RIDER does not have this light).
3. Leave your GO connected to the power cable and RESET it using a straightened paper clip
4. Press the ON/OFF button for at least 3 seconds.
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
4. Turn your device on.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
If your device uses an SD card, insert the SD card.
Always make sure that you are using the latest version of the TomTom application on your device. You can update the application through TomTom HOME. If you use more than one storage card you need to update the application on each card.
Apr 04, 2008 | GPS
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
My battery died this morning when trying to start my kadasaki KLR650 in the cold. I hooked the charger up a few hours later, but still can get no charge. I rode this bike five days ago. I charged it at...
it should have done no harm providing that you connected the charger positive to positive and negative to negative
however if the battery has a bad cell , then charging it will achieve nothing as that bad cell takes all of the charge and does nothing
have the battery load tested , then have the charge circuit of the bike tested properly by a bike auto electrician
Nov 09, 2017 | 2008 kawasaki KLR 650
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Sep 01, 2008 | Tomtom RIDER GPS Devices
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
Tomtom RIDER GPS Devices Logo
709 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
