FixYa.com
Tags:
SGI Silicon Graphics GDM 4011P 20
The screen seems dead
posted by bono1 on Aug 05, 2007
i try to turn it on but nothing happens, how can i know if the monitor gone?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 05, 2007
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 87%, 2240 votes
Hi, normally monitors have an indicator light that lites up when power is applied. This changes color or another lites up when it receives video signal from the computer. If no light then most likely defective monitor.
Possibly the only way to positively check is to replace it with another known good monitor and connect to the PC. Power up and there should be a display. If there is then the 1st monitor is defective, if still nothing then it is the PC that is defective.
It might also be worth to check/replace the power cord and/or video cable if applicable.
Hopes this works out for you. Good luck and post again how things turn up.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Monitors
monitor problems
please give me circuit diagram... Answer This...
Monitors
15 inch onitor amsung
"Control Lock" sign... Answer This...
Monitors
monitor stops display
My ViewSonic TFT monitor stops... Answer This...
Monitors
mitsubishi nxm56lcd monitor
Powers up and is black or very... Answer This...
Monitors
MAG Innovision monitor
The bottom left of the monitor... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
