Question about Mitsubishi CS-35607 TV
Mitsubishi cs-35607 - Everything is Red
That is the only color I get. Things that should be dark colored are black, everything else is RED. It was fine, then POOF. RED. None of the "authorized" repair locations around me seem to know what I am talking about. One even went so far as to tell me to "go to the menu & adjust the color." Can you help, or should I just trash can this thing?
  • 89 Answers
This is a known issue which requires the replacement of up to 3 chips and the addition of a modification ( diode)
The IC's are AN5268K
The modification requires the installation of a diode 1N4148 connected between diode D6XAL and Diode
The 1N4148 anode to D6XAL anode. The cathode of 1N4148 should be connected to the cathode of D6F04
You should also re-solder any bad connections on the board.
If you are at all unfamiliar with replacement of IC's or hesitant you should have the work done by a qualified technician
Posted on Mar 13, 2009
I have a Mitsubishi CS-35405. It has worked fine up until yesterday. When I turned it on the sound was fine but the picture is very blurred and the colors are pretty much all red and green. I tried the...
As old as this set is I worked on a lot of them.
Red and Green only?
These sets among other things with age develop bad solder connections: I suspect on the board that plugs onto the end of the picture tube you have some broken solder connections--the red, green, and blue video output circuit is there.
The really hard part with this set is just getting it apart--weighs a ton.
Let me know if I can help (not picking any set that heavy up).
Mar 31, 2012 | Mitsubishi CS-35405 TV
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
What color wires connect on an aftermarket cd player?
hot at all times: blue/red
hot in acc or run: blue/black
ground: black
illumination: red/black + green
RF speaker: blue/white + orange
RR speaker: black/white + blue
LR speaker: black/red + red/blue
LF speaker: violet + pink
this is for factory am/fm stereo non premium sound
Mar 04, 2009 | 2001 Ford Escort ZX2
Print images look like a rainbow, going from blue to red to blue to red etc.
I am on my way to a couple of appts. I waill answer early afternoon, Joe
Oct 06, 2008 | Ricoh Aficio CL3500N Laser Printer
Color problem
Good Day, pmusso:
The lamp may be going bad/weak.
You can replce it yourself it's easy; call mit's they send to your home with detailed instructions.
Good Luck, big IRISH.
May 26, 2008 | Mitsubishi WD-52725 52". Rear Projection...
CS 35607 Mitsubishi TV No Video
Please CLICK HERE and once you are at the site enter your model no.
Apr 18, 2008 | Mitsubishi CS-35607 TV
Can you please give me the make and the model no. so that i can find a schematic for you.
Waiting for your reply..
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Mitsubishi 36" model cs-35607 lost BLUE
All the IC's have a location number printed on the pc board, look for an IC with IC6F01 next to it.
Sep 06, 2007 | Mitsubishi CS-35607 TV
Televison & Video Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
