Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony Grand Wega 50" loses channel programming after turning off
We have a 50" Sony Grand Wega that is about 5 years old. Recently, the lamp needed to be replaced. After replacing the lamp, the TV now loses all the channels in its memory every time it is turned off for more than a few minutes, and needs to be reprogrammed. For example, if we are watching channel 5, then we turn off the TV and go to bed, the next morning the only channel the TV will get is channel 5, until we run the channel program function again. We are not using a cable box.
Any help would be greatly appreciated. Thanks
  • 84 Answers
SOURCE: Sony LCD Grand wega black and white picture
12000 hours you are lucky most last 2000 hours
lamp not the usual suspect for this
confirm black and white on all inputs and it will be more sinister, if only one input, it could be the signal source
Posted on Jun 22, 2008
SOURCE: Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
Posted on Sep 02, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
  • 1525 Answers
SOURCE: reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Posted on Nov 06, 2009
phil_frye
  • 295 Answers
SOURCE: I have a 50' Sony Grand Wega red bar on top of screen
Well this is an LCD projection TV and it sounds like one of the polarizer filter has gotten out of place so you are seeing at the top of your screen the unfiltered image of the LCD panel.
Will need to go into a shop to get repaired. Call and get an estimate of repair. Actually shouldn't be too bad of a repair cost.
Blessings,
A/V Media Tech Guy
Posted on Dec 20, 2009
My Sony KF50WE610 50" Grand
You just need to replace the lamp, put the model number in a search engine and chose the best priced one for you
Jun 12, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My sony grand wegas will not turn on no picture no sound .
Most possible cause would be broken/ dead lamp in your Sony grand wega tv. Check and replace lamp if it has not been replaced in last 2-3 years.
Do you see lamp red light on tv front or its power light is blinking? Let me know to provide you more info.
Thanks.
Jun 12, 2010 | Sony Grand WEGA KF50SX300 50" Television
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega-lose picture and sound then it returns after 1 minute. happening more frequently. now on for 3 minutes, off for 1.
Have you replaced your lamp since purchase, if it has been at least 2 or more years, replace the lamp first.
Oct 18, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blinking Red Light-50" Sony Grand Wega
It sounds like Lamp is broken in TV and requires replacement.
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony Grand Wega KDF-E50A10 50". Turned on the TV and all 3 indicator lights came on RED. There was no sound and nothing was on. Killed the power to the tv , waited 5 mins, rejuiced and it turned...
3 blinks red light is a lamp error, either the lamp switch is dirty or lamp is going, if it does it again reseat the lamp and see if it stops.
plan on replacing the lamp every 2 years or so anyway
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
50" Sony rear projection only 2 years old, will not curn on..
Your Fan could be bad, pull back off watch when you turn set on if fan stops running lamp and set will not come on. I had set that fan would sometimes run for all day then set would go back to not turning on. finally would not come on at all It was fan going bad.
Dec 20, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
