Question about Kenmore 74602 Gas Dryer
How do i test a thermal fuse on a kenmore dryer model number 11066732500?
  • 201 Answers
A fuse is tested using the continuity or resistance (ohm) setting on a multimeter.
Disconnect the power to the dryer. Disconnect the leads to the fuse. With the meter set on continuity, the meter should beep - if you set to ohms, you should read 0 ohms across the terminals of the fuse. If you read infinity, the fuse is bad.
Posted on Mar 13, 2009
Kenmore dryer model #110.80754001 NOT HEATING
you checked the element so you know how to use a meter good,go in the back again,look at the duct that the lint filter goes into down low and to the right you'll see a white part with two wires going to it,that's the thermal fuse,pull at least one of the wires off and check for continuity,if you haven't cleaned out the dryer and vent line this usually pops,if the dryer can't move air from lint blocking the air flow the fuse will pop because the dryer is running to hot,if the fuse is good check the t-stats on the heater box for continuity.common things to go thermal fuse or t-stats on heater box,all has to do with dryer running to hot.thermal fuse is part WP3399849,you can go here to see all parts in machine
https://www.searspartsdirect.com/model-number/11080754001/0582/0152000.html?searchType=modelSearch&q=110.80754001&searchTerm=110.80754001
go here put model number in
Jan 25, 2018 | Kenmore Dryers
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
May 16, 2017 | Kenmore Dryers
Kenmore elite 110.7703 no heat
Hi there
From the model number it seems this machine was made by Whirlpool for Kenmore. The thermal fuse is on front bottom near the blower wheel.
a) Pop open the front panel.
b) Then remove front door panel by removing the two secrews
c) Remember to disengage the door switch wiring
d) you will see the thermal fuse near the blower compartment.
e) If thermal fuse is burned out then it should not have continuity on OHMS scale on a multimeter.
Dec 07, 2013 | Kenmore Dryers
Kenmore 70 series electric dryer.where is the thermal fuse located?
Go to the sears web page, parts direct, put in the model number, look at the diagrams and you should find two thermal fuses, test them for continuity.
Dec 15, 2012 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Have a Kenmore model # 97591240. Dryer is not
Hi, if the igniter is not glowing then the problem will be with the thermal fuse. I'm going to assume this is a whirlpool made Kenmore since you did not provide the full model number so please remember this when rating. If you remove the back from the dryer and look down and to the left you will see the thermal fuse it looks like this:
http://www.applianceblog.com/mainforums/attachments/whirlpool-kitchenaid/415d1159395986-dryer-timer-wiring-thermalfuse.jpg
Pull the wires off and test it with your ohms meter. If as I suspect it reads open replace it. If you have any other questions please feel free to comment. Mike
Jan 02, 2010 | Kenmore Dryers
Kenmore dryer model 86870800 won't heat
thermal fuse is behind blower housing on models w/lint screen in door and on the back of the dryer on lint screen on top models.
May 24, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Electric kenmore dryer 11066732500
Its possible that sometime when you were touching the wires that something came unplugged, or moved and short circuited
Mar 13, 2009 | Kenmore 74602 Gas Dryer
Fuses
We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
lantzer@hotmail.com
Mar 08, 2008 | Kenmore 63942 Dryer
Kenmore 74602 Gas Dryer Logo
1,555 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
