Question about APC Back-UPS Pro 650 UPS System
Back ups battery rpo1100 APC disconnects the Dell PC power button
Pc wont turn on I have a 6 yrs. olc ups back battery connected to the pc. should I replace the back up battery named APC to fix the problem?
  • 1,066 Answers
Try plugging the pc directly into the wall...if it works the UPS is defective.  You can order new batteries for the UPS online.
Posted on Mar 13, 2009
How to replace an apc battery back up battery
Depend on model.
For 600VA and above
Go to APC site and check model of replacement battery.
Peel open the front plastic panel and unscrew 2 screws of metal panel.
Batteries can be slid out and replacement done when PC is online.
Only two wires to disconnect and connect.
Apr 21, 2014 | APC Computers & Internet
Apc 650 back-ups does not boot
try turning on the power connection
Mar 22, 2013 | APC Back-UPS Pro 650 UPS System
The monitor wont display when the pc is turned on [dell latitude d 630]
Try the steps below.
1. Turn the computer off.
2. Take the battery out.
3. Unplug the ac adapter
4. Press and hold the power button for about 15 seconds.
5. Put the battery back in.
6. Plug the ac adapter in.
7. Turn the computer back on.
The diisplay should be back on. Thank you for visiting FixYa! have a nice day.
Apr 21, 2011 | Dell Latitude D630 PC Notebook
Computer will not start up only sometimes after it sits for days but after shut dowm wont start up again
Try performing a hard reset on the laptop by removing the battery, unplugging the Power Adapter and disconnecting external devices connected to the laptop. Once everything is removed/disconnected, press and hold the power button for around 15 seconds. Put everything back then power the PC on. The reason this issue happens is because the computer doesn't shut down properly and because of this charges get left on the laptop's motherboard, holding power button down with nothing connected to the PC drains these charges. If still the same issue exists, try updating Windows, there might be updates that doesn't install completely. Update drivers as well and run a system scan with your security software.
Hope this help. Goodluck!
Mar 29, 2011 | Dell Studio 1537 Laptop
When the power button is turned on my apc350 makes a high squeal sound, what is this? I have to have it turned on to use anything that is plugged into the battery backup outlets.
Double check the connections on the internal battery. If you have had the unit for a year or longer it may be telling you your back up battery isnt any good. I suggest replacing the battery, go here
Mar 15, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
APC Back-UPS Pro 650 UPS System Logo
139 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
