Question about SanDisk Sansa e250 MP3 Player
It keeps saying that its refresing database and is not loading
My MP3 sandisk player keeps saying that it needs to refresh the database when its not loading up the database.
    Problem Solver:
  • 14 Answers
First try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Posted on Mar 14, 2009
Sandisk sansa clip mp3 player
i need to know how to refresh data base
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?
Try this
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Jun 19, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 10, 2008 | SanDisk Sansa e270 MP3 Player
"refresh database"
try formatting the hole mp4 *the musik partition only!!* or
try to use the recover mode and reinstall the hole mp4
more information u finds on google....
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa screen turns black after "refreshing database"
how about updating the firmware?
OOOOHHHHH
now we are getting somewhere
( how could someone not figure that out.... ha ha ha)
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
Refresh Database
I have the same problem and can not figure it out!!! how do I refresh database??!!!grrrrrr
Need help as well.
Thanks
Dec 12, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
"Refresh Database"
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Nov 15, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Try emailing SanDisk technical support team at: support@sandisk.com And ask them for the Recovery Mode firmware upgrade (Also send them the problem the way you posted it here). They should send you a link to some firmware upgrade file. You could also try calling them at: 1-866-726-3475 but an email should be sufficient because, from what I remember, it is just a link to file that you need to download. I hope that helps...
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
