Home | Toshiba | MW20FM1 20 in. Combo | Vertical problem
Toshiba MW20FM1 20 in. Combo
Problem for Toshiba MW20FM1 20 in. Combo
Vertical problem
By kdv_ssi on Mar 13, 2009
when you turn on the tv, all i get at first is a one inch horizontal picture(squished) sound is ok, after a minute or so the picture will be ok except the lower part of the picture 1 inch is folding and jittery, i replaced the vertical output amp ic NTE7188 , but i think its a leaky cap somewhere.........
Comments:
Mar 13, 2009
- are their any vertical problem service updates from toshiba on this model? maybe a list of capacitors to replace?
Mar 13, 2009
- can you e-mail schematics for the model?
Best Solution
posted on Mar 13, 2009
Very Helpful)
oolish
Rank: Guru
Rating: 86%, 61 votes
Have you checked the capacitors in the immediate vicinity of the vertical IC.
I would especially look for capacitors that are bulging on the top.
Also i would use the original output ic, NTE crosses are not 100 percent reliable when you have fold over issues.
Solution #2
Not Rated)
Blu3Demon
Rank: Wiz
Rating: 77%, 48 votes
Your correct and another thing it sounds like there was a audio /video plug that was plugged into the wrong outlet
Solution #3
Not Rated)
ginko
Rank: Guru  Toshiba Expert Televisions & Videos  Expert
Rating: 89%, 4933 votes
Solution #4
Not Rated)
famoussir
Rank: Wiz  Televisions & Videos  Expert
Rating: 83%, 42 votes
the whole board needs to be checked .as its the problem of overheated or burned ic and not the leaky capacitors .
Solution #5
Not Rated)
top class
Rating: 82%, 36 votes
ic401 will be  shorted it takes la78041. But it also had two shorted diodes #30b,which crosses to a nte7188.
 ,which in your  case needed 2 caps c421 4.7/50v and c427 100/35v . change both at same time. also in my search of the board c402 4.6 /160v had been puffed up either from the i.c. shorting or another potential problem so change while you are in there as well as resoldering the whole vertical/ horizontal circuit board.
Solution #6
Somewhat Helpful)
final answer
Rating: 80%, 56 votes
it could be because of any component getting overheated on the main board.as they gets faulty due to overheat so its needs comple checking by a professional as they have replacement spare parts ready at their work shop and the exact fault can be acquired.
Solution #7
Somewhat Helpful)
ssolved
Rating: 77%, 108 votes
check out the capacitor number C13013 JC on the main board and its near by components to locate the faulty.which would be bulgy or burned up.also check out with meter.
Solution #8
Somewhat Helpful)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 914 votes
Hi
You can enter into service mode and from there you can adjust your picute . You can do this by :
TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV.
You are now in adjustment mode:
5Use the 'Channel up'or"Channel dwn' to select the item.
6. Write down the old value of the item before changing.
7. Use Volume up and down adjust the value.
8. When you have made all the adjustments you want turn the set off to exit.
Solution #9
Somewhat Helpful)
livetech
Rating: 84%, 144 votes
exactly there are some faulty capacitors on the board causing this.check and replace the capacotor also dry solder whole board.
Popular Solutions for Toshiba MW20FM1 20 in. Combo
Questions and Unsolved Problems for Toshiba MW20FM1 20 in. Combo
Do you recommend Toshiba MW20FM1 20 in. Combo?
Answer
Answer
Hooked up external Toshiba DVD player to Toshiba MW20FP1 TV/DVD/VCR combo. Red,yellow and white... (More)
Answer
The remote censor does not work. Is there a way to access the menu function manually?
Answer
I have a Toshiba MW20FM1 when I turn on the power light comes on but no picture or sound
Answer
I need the programing codes for the remote so I can program the remote that came with my cable box... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba MW20FM1 20 in. Combo:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
